Oldsmobile 350 engine, remanufactured long block, includes many extras -$1,000
Old May 15th, 2013, 02:40 PM
superbee_68's Avatar
This is a complete oldsmobile 350 motor built by reputable Oldsmobile machine shop, cost me $1,500 just for the engine. I have all documentation and cam card. Stock rebuild with all new parts, valves have hardened valve seats for unleaded fuel. Inludes new oil pan, timing cover, 4 barrel intake manifold, electronic distributor, valve covers, oil pump, water pump, starter, and fuel pump. Everything you need to drop it in your car. I can also sell seperately pulleys and brackets for accessories. This motor has been sitting in a plastic bag since received so it is still new. I'm asking $1,000 for everything. I have well over $2,500 in the motor and parts.
Robert
(817)seven-one-eight-0220
superbee_68 is offline
Old May 15th, 2013, 02:55 PM
drop top olds's Avatar
Some more information about the engine would help generate interest.
Heads?
compression rato
list any important machine work performed i.e. zero decked, align bore, etc.
Looks like a good price as you can't touch a complete rebuilt engine for that price point.
Good Luck Sir.
drop top olds is offline
Old May 15th, 2013, 03:05 PM
Cutlass65's Avatar
What year ? I am very Interested If u Still have please call andrea at 7753783113 want whole engine please
Cutlass65 is offline
Old May 15th, 2013, 06:45 PM
As far as specs go, it's a stock rebuild. Every single spec will be what it was stock for a 68 model cutlass. It was done by S&S engine remanufacturing. I've got the paperwork from S&S. It's a Remanufactured engine part number 35041.
Old May 15th, 2013, 06:54 PM
Stock 2bbl or stock 4bbl specs?
MDchanic is offline
Old May 15th, 2013, 07:07 PM
L69
L69's Avatar
what are the numbers on the heads. front left corner on drivers side back left corner on pass side. should be something like 5-8. Prob 8 as S and S tends to use whatever they have plentiful
L69 is offline
Here is the link on their website. The info on here is all I know. This is the website I bought it from.
http://www.rebuiltautoengines.com/ol..._4-engine.html
Old May 15th, 2013, 07:13 PM
#8 heads on the motor.
Old May 15th, 2013, 07:56 PM
Then it is not "... a stock rebuild. Every single spec will be what it was stock for a 68 model cutlass."
A '68 Cutlass would have #5 heads. #6 or #7 would be similar enough to be considered within the bounds of a "stock rebuild." #8 heads have a much larger combustion chamber, and no chance of obtaining the same compression, unless seriously decked.
Unless your builder specified that the heads, pistons, and block had been cc'd to the '68 spec., and described how, one could not conclude that this was a "stock" '68 rebuild.
MDchanic is offline
Old May 15th, 2013, 08:31 PM
I'm not trying to deceive anyone. The parts were chosen by S&S and the motor was put together by S&S. I ordered it off their website. It is supposed to be a stock reman motor. If you want every number or part to be a perfect match for your car, then this motor isn't for you. Rebuild your stock motor or source parts. This is an engine for a driver that needs a motor, or for someone on a tight budget. I'm including a ton of parts to complete the motor, all new. My loss, someone else gain. I'm selling because I sold my car and no longer need the motor.
Old May 15th, 2013, 08:52 PM
I'm not trying to say that you are. You may just not know the differences in specifications.
But the fact is that without specific information to the contrary, indicating machine work that is not usually done, the presence of #8 heads, which have very different combustion chamber volumes than #s 5, 6, and 7 have, means that this engine is NOT built to 1968 specifications, which called for either 9:1 or 10.25:1 compression ratio, depending on whether the engine was a 2bbl or a 4bbl (as I asked before).
This is not a question of "every number or part" being "a perfect match," but of whether the engine is, as you say, built to 1968 specifications, or whether it is built to other specifications. The answer to this question may be important to a potential buyer.
I'm trying to help you here, because if someone bought this engine expecting a 10.25:1 motor, and received an 8:1 motor, they might be a bit peeved.
MDchanic is offline
Old May 16th, 2013, 10:57 AM
jpc647's Avatar
Where are you located? The paperwork mentioned above, does it state was S&S did to it? Can you post or email me a copy?
jpc647 is offline
Old May 16th, 2013, 12:03 PM
I am located in Fort Worth TX. I'll post pictures of the paperwork when I get home.
Old May 16th, 2013, 12:51 PM
Kennybill's Avatar
Great deal for someone who needs an engine. You should look for a gbody Cutlass and drop it in. Ken
Kennybill is offline
Old May 16th, 2013, 04:29 PM
Geez people for $1k your either in or your out. It's a jobber rebuild not a performance engine. It would be great for a DD or a budget builder.
oldcutlass is offline
Old June 26th, 2013, 09:10 PM
Still available.
Old June 26th, 2013, 10:34 PM
Grace Stinespring-Welch's Avatar
engine
that is good deal no matter what. parts alone cost more than that. i don't have room in my garage ,or i would buy it just to have it.
Grace Stinespring-Welch is offline
Old June 27th, 2013, 08:06 AM
jpc647's Avatar
ever get a chance to upload the paperwork?
jpc647 is offline
Old July 7th, 2013, 09:04 PM
Sold.
Dead Reckon
May 5th, 2015 11:18 PM
SteveSS
February 21st, 2015 05:52 PM
auto_editor
Vista Cruiser & Wagons
April 10th, 2011 09:21 AM
BerBer5985
August 12th, 2009 10:29 AM
ckimble
May 18th, 2008 09:55 AM
Quick Reply: Oldsmobile 350 engine, remanufactured long block, includes many extras -$1,000
