Bucket, Bench & Rear seat padding, repair & install kits
Getting ready to restore your car's seats, but don't know what all you might need once you get the old covers off?
I sell kits that include all the OTHER stuff you will need.
Bucket Seat Padding & install Kit - 64-72
Kit contains material to re-build (2) bucket seats:
(4) 25x25 burlap squares
(4) Precut jute decking sets (1 center, 2 bolster pieces per cushion)
(2) Jute spring insulation sets (lower fronts, lower inner & outer sides, upper cushion top center)
(4) 60" paper covered wire rods (for use inside the lower cover sleeves, or to replace the listing rods on the spring assemblies)
(5ft) 11ga Medium loop springs (bottom & upper cushion)
(5ft) 9ga medium loop springs (bottom cushion)
(35) spring clips
(1) bag of hogrings (enough for pair of buckets)
Bench Seat / Rear Seat Padding & Install Kit
Kit contains material to re-build (1) front Bench seat, or (1) Rear Seat:
(2) 66" burlap sheets
(2) 66" Jute decking sheets
(4) 60" paper covered wire rods (for use inside the cover sleeves)
(35) spring clips
(1) bag of hogrings (enough for 1 bench or 1 rear seat)
These kits are $80 each+$19 shipping (USPS Flat Rate large)
Buy two kits and I will take $10 off each.
Have specific seat spring repair needs?
Tell me when you order and I can make them here and include them ready to install with your kit.
ben@classicseat.com
*** NOTE:
These kits DO NOT INCLUDE
Seat Covers
Seat Buns\Foam
Cotton batting
I can help provide guidance for purchasing those items if you need.
(35) spring clips
(35) spring clips
ben@classicseat.com
*** NOTE:
Seat Covers
Seat Buns\Foam
Cotton batting
Yes, I send photos showing how the pieces are supposed to be installed- and I offer support, tips and guidance for the actual cover installation process for folks who buy from me.
I've helped quite a few folks restore their first set of seats via long distance.
I just want to clarify as i've had a few people ask me...
These kits DO NOT include: Seat Covers, Seat Buns\Foam, Cotton batting
These kits provide all the OTHER items needed to properly restore seats that are often left out or are difficult to obtain, in one combined kit.
Hello Ben, I have a 70 Cutlass convertible, bench seat with an middle arm rest. The bottom seat is very soft and springy. I have to use a hard plastic board to sit on it. Do you sell just the bottom spring?
I have generic medium loop spring in 9ga & 11ga that I sell by the foot that is used used to repair broken GM Seat springs, but I don't sell complete spring assemblies.
Typically ALL of your springs are not likely bad, you probably have one or two (or 3 or 4 LOL) broken which lead the whole thing to feel like it has no support.
Fix those and you'll be back in business... But you really need to pull the seat out and strip it down to properly figure out what exactly is wrong with it first, then make a repair plan.
HIt me up if you have any questions, I'm happy to help!
Hi Al- Thats not really what this thread is about, and its not the kind of project that I do- but for that project you are looking at a lot of spring and frame fabrication work along with 100% custom upholstery work.. I would estimate you will be looking between $2k-$3k to complete that project.
At least thats what it would cost in THIS area to walk in off the street and have a legit shop do it.
Much cheaper and easier to just locate a set of factory buckets and have them restored with reproduction covers.
Ben, this looks like a really complete kit that should bring back the original feel and eliminate those popping noises considering it comes with springs. I've never done springs before, I assume these are cut with a die grinder and clipped to the frame sort of like hog rings?
You can use a die grinder to cut springs and edgewire, but i find it quicker and easier to use bolt cutters- but yes, there are spring clips (included in the kit) that are used to clamp it all together. Seat spring assemblies are all clamped together, they are not welded (makes spring steel brittle, and it breaks).
Send me an email with your needs and I can hook you up.
benrambow@gmail.com
Will definitely hit you up when I do my buckets, although I suspect that will be a next winter project. If you were close, I'd just hire you to do it. We have shops around here, but they don't spend much time getting the foundation correct. And while the final product looks nice, you might end up with that crunching spring sliding over spring noise or the dead spring, soft spot. My "opinion" is that replacing springs is critical, especially on the high fatigue driver seat.
Ben, do you have any advice on preferred vendor for the actual covers? It seems most folks like Legendary, but I don't have enough experience to know what the difference is.
Bringing back to the top-
I am still making these kits... Still making custom spring repair parts.
If you are still stuck at home, this is a great time to restore your seats!
Cost on the Install kits has risen a bit since this was posted, they are now $100 / kit + $20 shipping, however I'll still knock off shippinig on the 2nd kit if you buy front & rear kits at the same time.
Hard to tell with the covers on, but the lower cushion looks nearly rusted through the stamped part of the frame.
I wouldn't toss anything until you have found a replacement though.
Also- this is a classifieds ad, so if you have seat project questions, please post them in the interiors forum where myself and others can see it and reply, or PM me about it if you don't want to post to everyone.
Thanks!
Ben
Thanks!
Ben
Yes! I do still make & sell these install/padding kits, 25ft rolls of GM medium loop spring in 9ga & 11ga, and custom made seat spring repair parts.
PM me or email with your needs at benrambow@gmail.com
Cheers!
Ben
Cheers!
Ben
Bringing this back to the top, I'm still making and selling these kits. Prices have increased, so reach out if you need anything or have any questions.
I am also still making custom repair springs- no need to spend $80+ each on entire new seat spring assemblies when you can get exactly the parts you need to fix them for a fraction of the cost.
I make heavy 9ga side support springs, and double reinforced front corner springs to greatly improve the feel of your stock seats without raising your seating height.
Bucket Seat Upper cushion "tension rods" 68-72 style
Top Center- Bucket seat Lower Cushion rear corner edge wire repair
Bucket seat Lower cushion "front corner springs" with reinforcements added
Heavy Duty Bucket seat Lower cushion side support springs (9ga vs 11ga originals)
Bucket seat lower cushion with Install Kit materials
Bucket Seat upper cushion with install Kit materials
#31
The basic kits are now $110+$20shipping (USPS Priority flat rate large).
If ordering front and rear kits together, I will knock shipping off the 2nd kit (Still comes in two boxes)
Spring repair parts cost depends completely on what is needed.... If combined with a seat kit, repair parts are discounted further.
email me or PM me if interested.
#32
These kits are the bomb for rebuilding your seats! If you don't need to replace your springs, then all you need is foam and upholstery, Ben provides everything else including step by step instructions in the kit.
RAMBOW
July 26th, 2016 08:05 AM
RAMBOW
June 21st, 2016 09:33 AM
RAMBOW
January 12th, 2016 07:29 AM
