olds gold engine paint
just fishing for opinions .ive read some old post on brands of engine paint to use .im not so concerned with exact match as i am with durability .thanks
Used this for many years on my cars: http://www.hirschauto.com/
thanks for the link .ive heard other guys recommend this as well .have you tried that rust paint they sell? it sounds similar to master coat which i have had good luck with .
POR15 looks great, goes on great, and stays on. However it burns around the exhaust ports and choke stove. Although it blackens, it does stay on...
Pics can be seen in the middle-end of my underhood resto thread.
I used Hirsch on my 54 and am very pleased with it. The color is very close if not exact. It has held up very well. Many folks say it is the closest to original. I have also used paint from Fusick and it is very good.
Does anybody know why rust spots can be seen under newly painted surface like i wire wheel brushed then a wire brush as well as sand paper..then primed and undercoated and brown spots still appear under the paint...no water no snow no salt
Also the time frame between primer and finish coat. Most primers don't seal off moisture. If for some reason a surface is primed and then weeks later the surface finish was applied, this would allow for rust to grow.
RAMBOW
March 14th, 2010 07:44 AM
