Convertible top pump
Old June 4th, 2014, 08:04 PM
servexcell's Avatar
I am restoring my 68 Cutlass Convert. I removed the electrical pump for the convrt top it has not worked in a while does anyone know what kind of fluid goes in , mine maybe leaked some out at the fitting that's why maybe it was not working
tnks bruce
servexcell is offline
Old June 4th, 2014, 08:13 PM
stlbluesbrother's Avatar
tnks bruce
Automatic Transmission Fluid (ATF)
stlbluesbrother is offline
Old June 4th, 2014, 08:20 PM
And here's a link to instructions on how to go about filling and bleeding the pump. The same info can be found in a Fisher Service Manual.
http://www.chevelles.com/forums/showthread.php?t=113945
Old June 4th, 2014, 08:22 PM
Gary M's Avatar
You can find bleed instructions on 442.com. Check if power is getting to the pump if it does not respond when you push the switch.
Gary M is offline
Old June 4th, 2014, 08:47 PM
Junkman's Avatar
I would drain a little into a class container. I remember them using hydraulic brake fluid, but that is a long time ago, and I might have remembered wrong. If i is brake fluid, it will remove paint, but if it is transmission fluid, it will be red. Check, because the two don't mix well.
Junkman is offline
Old September 21st, 2014, 12:59 PM
In researching this very thing, I read in the 1966 Fisher manual to use brake fluid. The next text I saw was the 1970 Fisher manual and it says use Type A (or equivalent) trans fluid. So somewhere between 66 and 70 it switched.
slantflat is offline
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
Tom442
August 11th, 2014 08:55 PM
deadeyejedi
March 3rd, 2014 10:12 AM
Bobac455
December 5th, 2013 01:15 PM
f85delta88andcutlassS
June 7th, 2013 04:36 PM
Quick Reply: Convertible top pump
