Removing clock delete plate bezel
Old March 20th, 2012, 10:35 PM
yeahbuddy's Avatar
I want to remove my clock delete plate in my 68 Cutlass Supreme to install a tach. Saw the idea in another thread. I see it move side to side when I try to move it from the front. What is the proper way to remove the lens and bezel?
yeahbuddy is offline
Old March 21st, 2012, 02:47 AM
Yellowstatue's Avatar
With the screws out and the wiring disconnected...push it straight from under the dash, back towards the steering wheel...
Yellowstatue is offline
Old March 21st, 2012, 05:00 AM
starfire's Avatar
It's a clock delete, there should be no wiring.
starfire is offline
Old March 21st, 2012, 11:20 AM
yeahbuddy's Avatar
So basically reach under then dash and push forward. The top part I am able to swing side to side but there is a latch on the bottom that does not release. Is it held in with a screw?
Old March 22nd, 2012, 05:25 PM
starfire's Avatar
There is no latch. Like Yellowstatue says once you have the two screws out, it just pushes out from behind. You may have to really wiggle it though as the screw heads that hold the clock delete to the bezel want to interfere with the edge of the dash pad. If you don't have an assembly manual, go to www.wildaboutcarsonline.com and sign up for a free membership. Then once you are logged in do this:
Go to "The Library" (top menu), then "Download Factory Published Materials", then "Oldsmobile", then "Assembly Manuals & Inspector's Guides", then "1968", then "1968 Oldsmobile A-body Assembly Manual", then "Section 1.3". You can then see what you are dealing with.
starfire is offline
Old March 23rd, 2012, 09:41 AM
yeahbuddy's Avatar
Thanks for the link! I need to figure out how to reach back there without ripping everything apart.
Old March 23rd, 2012, 06:19 PM
yeahbuddy's Avatar
Thanks guys. Layed upside down on my bench seat and sqeezed my hand enough to unwind the screw. I wanted to remove the clock delete place to install a (cheap) dash tach. I got this Sunpro Mini Super Tach for $22 shipped. That was my only expense. I think it came out looking good! Will install sometime this week. Thanks again.
Old March 24th, 2012, 03:37 AM
The hard part is to get the screws started... If you have small hands and are a Doctor with a lot of patients, then go for it...
88hurstolds
April 15th, 2014 04:32 PM
D Appeldorn
October 19th, 2010 11:26 AM
defiant1
April 25th, 2010 09:03 AM
kjr442
March 31st, 2010 08:56 AM
squirell
November 20th, 2009 06:34 PM
Quick Reply: Removing clock delete plate bezel
