Is this a vented gas cap?
I'm just crossing my T's and dotting my I's. When I first bought my car (and didn't know squat) I deleted my charcoal canister and capped off the vent pipe under the hood (passenger side). Every once in a while, while in the garage, I hear a strange noise and come to find that it's either air escaping or entering the gas tank around the cap.
And one day I overfilled the tank and immediately parked in the direct sunlight which caused fuel to leak out of the cap (I think it was the cap, it was a while back). So it sounds like I have a vented cap but often, when pulling the cap off, it pops air (when it's hot out) or it's hard to get off because of suction (like this morning). So that sounds like it's not vented. Any ideas?
I blew some air through the little hole in the center with a portable, automotive compressor and the gauge on the compressor didn't change appreciably. But that doesn't explain the air rushing out of the tank when the cap is removed.
Okay, I think I have a non-vented cap. Or at least a cap that isn't venting. I went out to check the other wording, which only says "Caution", and when pulling the cap it was a bit stuck-on and when opened it sucked in air, and quite a bit. Even with the original charcoal canister system, it would at least need to pull in air so as not to create a vacuum, yeah? Any recommendations on a replacement cap? Or will anu old off the shelf item work okay?
The CSM states: "A positive two step locking pressure vacuum type filler cap is used on all models." And that's about it. What does "vacuum type" mean?
You should replace with the exact same cap. The matured age dude at the store was correct. It only let's outside ambient air INTO the gas tank. The fuel pump is a mechanical pump. The mechanical pump creates a vacuum in your tank as the fuel pump pulls fuel from the tank. The air space ABOVE the fuel is less dense (less pressure) than the ambient air pressure on the outside of the fuel tank. Therefore, to equalize the pressure in the fuel tank, the one way valve in the gas cap only allows air in (to equalize the pressure). It does look like your gas cap is toast.
Mine says nothing. It has the letter 'S' on the top (not that it should matter what it says anywhere on the top of the gas cap as long as it is of the same type of pressure vacuum cap). And, yes, that one-way valve inside the gas cap is designed to open under a certain amount of vacuum within the tank - but at the moment I can't recall WTH that pressure differential is to be honest.
Maybe the "S" stands for super, like on the trans, lol. I wonder if the cap can be oiled or something. I may soak it tonight, just in the little hole, and then apply my vacuum pump tomorrow.
I believe what becomes confusing are the terms used to describe certain parts. It truly is, IMO, a Pressure Vacuum Cap. The term 'vent' is a misnomer, IMO. There's a one-way valve inside this Pressure Vacuum Cap. I would normally consider a 'vent' to be something which allows a gas to freely 'leave' an area of it's own volition. As in a true vent. But, that's just me.
But then again, I call a motor vehicle 'propeller shaft' a drive shaft. My CSM thinks otherwise.
https://www.opgi.com/cutlass/BR01997/
Thanks Kenneth. I knew I thought that 'S' stood for a manufacturer but I couldn't recall where I'd seen it.
Well huh; mine has the S in the middle as well. Not the original cap. First thing I've found that wasn't original. That is, except for that awful triple electric fuel pump setup with the scary wiring.
Summit claims this is for a '71 Supreme;
https://www.summitracing.com/parts/s...utlass-supreme
I always double-check part numbers. Sometimes parts supply houses display an image which 'closely resembles' the part you'll receive - LMFAO!
However, the number Summit demonstrates is 10807.
Go to STANT and input your numbers for your car and you'll arrive at the STANT part number which does match the Summit part number (in this case).
The only delta I see is the depth of the cap which goes into the neck of the fuel tank. The depth of my cap is rather deep and protrudes into the tank a decent depth. The images look shallower to me - but hell, images are difficult to decipher.
And, did they change them over the years since the time mine was replaced?
Sometimes parts houses just plain PI$$ me off. Who is to say a particular manufacturer and/or supplier doesn't subcontract out the work to someone else. Sometimes it's a hit or miss ballgame.
I'd go out and measure the depth of my cap but I'm heading to bed as there is golf to be played @ 8:00am!
Rockauto has it for $2.98, of course the shipping from either house will probably be $15.
I'd hit up a local auto parts store, NAPA, Autozone, Kittrel's etc. Most have them in stock in some warehouse - they stockpile this stuff. Let them do the shipping for free and you pick it up at their store.
https://www.rockauto.com/en/catalog/...+tank+cap,5900
Summit is usually really good about matching replacement parts and, unlike Rockauto, they actually have a phone number and a realistic return policy.
Thanks for looking up the part #, I appreciate that. Looks like Advance carries it too.
https://shop.advanceautoparts.com/p/...986%7CL3*15390
Golf on a Wednesday morning? Sounds like someone is retired I hope to join that club in a few more years.
The original cap was probably left sitting on top of a gas pump sometime in the 70s.
I think back and remember many times seeing caps on top of the pump at the station, cars driving down the road with the gas cap sitting on the roof, mangled caps on the side of the road, etc.
#31
#32
You should have a non-vented cap. You can pick one up at any parts store - they're all the same stuff from Stant.
If the car has a charcoal canister then it uses a non-vented cap. Earlier cars without the canister use a vented cap.
If you're having pressure problems then the charcoal venting system is clogged somewhere. Could be the canister, any one of the many lines, or even the stand pipe behind the back seat.
#33
I think you're right. Do you have that plastic vapor vent on the other side (towards the front of the car) of the gas tank? It has 2 hoses connected to it. That vapor vent has like a small sponge like filter inside. Also, since you disconnect the charcoal canister system, all that vapors is still stuck in the gas tank and its pressurized. This is why the cap has that "CAUTION" asking you to open slowly. If you have a vented cap, then all vapors will escape thru the gas cap and you'll be smelling gas like if you're leaking gas? Im picturing if you're drink your drink with a straw and has a tiny pin hole in it. You'll be sucking your drink with air. I think your fuel system is like a straw without that tiny pinhole. If you know what I mean? You can correct me if I'm wrong. We all can learn something new.
#34
I worked at a similar Mobil station back in my school days. Half full serve, half self serve, two mechanic bays, one oil change bay, and a tire machine. Thinking back on it, we did a lot of stuff that I wouldn't trust a school kid to do these days.
#35
Nah, we were more new-age than that, unfortunately. We had a convenient store, very small, and a car wash with the spinning brushes. Bloomington used to host a huge Corvette show; cars from all over the world. I remember filling up Vettes from Hawaii and Germany. I also remember only changing the price signs maybe twice a year for the first few years; '78-'81. I was there until '88, when I went to sell hardware, lol.
