Penetrant for plastic? - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Other
Penetrant for plastic? >
Old May 22nd, 2018, 08:54 AM
Gearhead
Jon442's Avatar
I have a '79 Lincoln that is all original. One of the reverse lights is out, and I went to remove the socket to replace the bulb. I suspect on this car, the socket has never been removed from the tail light housing. So, it's stuck in there tight. I've tried to turn it and tried pushing while I turned it, but no luck. It won't budge. Is there any kind of penetrant, like penetrating oil, that is safe to use on plastic? Otherwise, I'm afraid I'm going to break something getting the socket out of the housing
Jon442 is offline
Old May 22nd, 2018, 09:04 AM
OLDSter Ralph's Avatar
I would think some kind of silicone spray that's safe for plastics at an auto parts store.
OLDSter Ralph is offline
Old May 22nd, 2018, 09:33 AM
^^^This. Use only silicone products. Any petroleum-based products will eventually attack the plastic.
joe_padavano is offline
Old May 22nd, 2018, 09:47 AM
Gearhead
Jon442's Avatar
So would WD-40 be safe?
Jon442 is offline
Old May 22nd, 2018, 10:05 AM
What do you think?
Old May 22nd, 2018, 11:16 AM
I've used Simple Green and a toothbrush in the past to clean and then disassemble plastic wiring connectors. It seems to work well.
Olds64 is offline
Old May 22nd, 2018, 12:45 PM
Tedd Thompson's Avatar
Try a heat gun or hair dryer that sometimes works. Don't get too aggressive and melt something..... Tedd
Tedd Thompson is offline
Old May 24th, 2018, 08:24 PM
Ozzie's Avatar
Try removing the other backup light socket. Sometime "technique" is important if you've never removed it before. Be sure there is no "lock" that needs to be released. Try the silicone. Try Tedd's suggestion. An extension of it would be to SLIGHTLY heat the housing while cooling the socket if you can. Another possibility would be to GENTLY tap on the socket. Also you could try one of the Lincoln or Ford forums. Someone else may have already had the same problem.
Ozzie is offline
NWG-body
October 30th, 2004 08:30 PM
emarkay
August 9th, 2004 09:12 AM
CTWalneck
January 12th, 2004 01:32 PM
CTWalneck
January 12th, 2004 01:30 PM
<CTWalneck>
January 12th, 2004 01:05 PM
Quick Reply: Penetrant for plastic?
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
