1975 Delta 88 Refrigerant suction/discharge A/C hose
does anyone know where I can get the a/c hose assembly for this car. I cant find anyone who have it and im not sure if they repair a/c lines. I need the 3/4" low pressure hose that runs from the expansion valve to the back of the compressor with the muffler/dryer on the end.
If you need to, you can usually go to a specialty hydraulic shop to get hoses crimped for your application. Did you check out Fusick ands Kanter already?
https://www.kanter.com/
http://www.fusickautomotiveproducts.com/
67442nut
December 27th, 2016 02:08 PM
