64 F-85 gas tanks with filler neck
Old March 8th, 2018, 11:19 AM
Mike Sundy's Avatar
Does anyone know if any company sells a 64 F-85 gas tank with the filler neck attached? Preferably for less than an arm and a leg. Short of that, can anyone recommend a place that sells the appropriate filler neck? Also, there are a lot of different sending units that could potentially fit. How do you pick the right one. Thanks in advance for any help.
Best regards,
-Mike
Mike Sundy is offline
Old March 8th, 2018, 12:21 PM
rpinnt's Avatar
I got mine through Tanks Inc. I bought the fuel injection ready one that has a two piece filler neck. It appears that the non-FI tank doesn't come with the filler.
http://www.tanksinc.com/index.cfm/pa...rod/prd304.htm
http://www.tanksinc.com/index.cfm/pa...rod/prd418.htm
rpinnt is offline
Old March 8th, 2018, 12:30 PM
Mike Sundy's Avatar
yeah, I saw that FI one and was excited until I realized it wouldn't work for my carb setup.
Old March 8th, 2018, 04:27 PM
rpinnt's Avatar
I am running a carb, just need a regulator to knock the pressure down from the FI psi levels to carb psi level.
rpinnt is offline
Old March 8th, 2018, 04:32 PM
Mike Sundy's Avatar
Thats a great idea! Do you have a link for the regulator? That would save a step if I ever switch to FI too.
Thanks,
-Mike
Old March 8th, 2018, 04:51 PM
therobski's Avatar
Awhile back I bought mine with the filler neck, I would have to look threw my receipts but it was made in Canada. I used a Rob-Mac pick up/sending unit.
therobski is offline
Old March 8th, 2018, 05:34 PM
rpinnt's Avatar
Thanks,
-Mike
I have an Aeromotive (maybe A1000?) that I had left over from another project, but I would think there would be other options.
rpinnt is offline
Old March 8th, 2018, 05:43 PM
2blu442's Avatar
If all else fails, I've got some good used gas tanks. If you just wanted the filler tube it appears to be soldiered on. I might be able to remove one and just ship you the filler if you wanted. John
2blu442 is offline
Old March 8th, 2018, 06:24 PM
Mike Sundy's Avatar
Old March 8th, 2018, 06:27 PM
Mike Sundy's Avatar
Thanks, John! That would be awesome! After looking at the the price of the FI tank with a pump and regulator, it'd be over $600. A $100 tank sounds a lot more reasonable. I'll check my current tank and see if the neck is in decent shape and let you know if I need one.
Old March 11th, 2018, 07:13 AM
Mike Sundy's Avatar
Here is what I'm working with. With the small bit of leakage, would it be worth it to just use JB weld and call it a day?
Old March 16th, 2018, 09:12 PM
2blu442's Avatar
Mike, I don't know if you've made a decision on this yet or not. I'd clean it real well and identify what's causing the leak. If it has a rust hole, I'd lean toward replacing. If its the solder where the filler goes into the tank, I'd try repairing that. John
2blu442 is offline
Stevec
March 13th, 2016 12:09 PM
Del70
July 17th, 2014 05:43 PM
DeltaDevil88
December 14th, 2012 04:13 PM
Aceshigh
August 22nd, 2011 12:47 PM
mryoung4815
May 28th, 2009 07:53 PM
Quick Reply: 64 F-85 gas tanks with filler neck
