Removing dash heater controls
Old June 6th, 2017, 04:34 PM
radioburningchrome's Avatar
How do I remove the dash heater controls without damaging the plastic on my 1997 LSS?
radioburningchrome is offline
Old June 6th, 2017, 05:25 PM
Olds Fever
CRUZN 66's Avatar
Here's some info from the 97 CSM... The image might be a little clearer once it is printed or magnified...
CRUZN 66 is offline
Old June 6th, 2017, 05:31 PM
Olds Fever
CRUZN 66's Avatar
Here's the page image split in two section...
CRUZN 66 is offline
Old June 7th, 2017, 04:54 PM
Thumbs up
That's what I needed. Thanks!
Old June 7th, 2017, 08:29 PM
When you're removing the wood grain trim plate, first open the glove box door and undo the screws that fasten it on the right side. Failure to do this can result in bending that strip and learning new blue words. The trim is held in place by friction fit clips all the way across the IP. Work slowly and gently. The occasional forced pull is sometimes necessary. I had plenty of practice with this when I had to troubleshoot my AC on the 95 Regency Elite.
Once the trim is off it's pretty straight forward.
Allan R is offline
Old July 19th, 2020, 08:13 AM
lemoldsnut's Avatar
Just reverse the order
lemoldsnut is offline
OLDSmobility
June 30th, 2012 08:01 PM
StickW31
November 23rd, 2011 05:59 PM
Beob
January 17th, 2011 08:50 AM
agtw31
August 20th, 2010 08:45 PM
Texas442
November 27th, 2009 05:01 PM
Quick Reply: Removing dash heater controls
