61 f85 oil pump cover Thrust Plate
Hi,
my oïl pump*housing is used by pump gear , that is normal , i think , so what is the best way , make a new smooth surface to the original oïl pump housing or using a Thrust Plate ?
the holes of the*Thrust Plate look like smaller than on the oil pump housing , i must enlarge them to have the same cavities than the oïl pump housing ?
Thanks for your help
