61 f85 right exhaust manifold
I don't know what intake manifold you have, but Eric is correct. The box on the manifold is the hot air stove for the choke. There should be a small diameter metal pipe from that box to the choke coil housing on the carb. The stock intake on the 215 does not have an exhaust crossover, so there is no way for hot exhaust to provide any heat for the choke from the intake manifold. There is a hot water passage under the carb, but that does not provide heat to operate the choke.
rocketcouple
January 31st, 2018 10:59 AM
