Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Well I bought another 63 F-85
Old June 6th, 2018, 03:14 PM
carbizguy's Avatar
So, my dads old car was in far worse shape than anticipated. I spent countless hours researching all the parts I needed and I finally came to the realization that it was just not cost effective. it was a major bummer.
So instead I began a search for a nice rust free donor, that was my intention anyway. I found one and it was the same color as my dads, it was solid so I bought it even though I probably spent more than I should've. This may be a driver instead.
It does have a few bugs to work out, most concerning is some white/blue smoke and the burning of oil. The previous owner said he spent $4000 on the motor rebuild. any ideas what to do first??
He also replaced the carburetor with a 500 cfm edelbrock. That seemed a little much to me and its not running right when its cold, then when it warms up it starts to smoke. He gave me the original 4 barrel Rochester that I planned on rebuilding, but I'm not sure what to do to solve this smoking problem.
carbizguy is offline
Old June 6th, 2018, 05:53 PM
jensenracing77's Avatar
I would look and see if they installed some kind of PCV on it and hooked it up wrong. It could be sucking oil through that. I believe that 63 was the first year for it on the Cutlass and F-85.
Looks like a nice car. A/C, power brakes, power steering...
jensenracing77 is offline
Old June 6th, 2018, 06:08 PM
carbizguy's Avatar
Thanks, its way better than my other one. I'll check the PCV out.
do you think the 500 cfm edelbrock could be part of the problem when its cold? It sputters and coughs for a little while
Old June 6th, 2018, 06:16 PM
I am the wrong guy to ask on carburetor issues. I can make a Jetfire 1 bbl carb work great but outside of that I am not very good with them.
Old June 6th, 2018, 06:24 PM
young olds's Avatar
The 500 shouldn’t cause running issues if set up correctly, worst thing might be lack of throttle response. Check to make sure your choke and fast idle are set correctly
young olds is offline
Old June 6th, 2018, 06:37 PM
carbizguy's Avatar
nice, thanks guys. I appreciate the insight. I'm not good with the mechanics part of it, so I will take this to my buddy who runs a local restoration shop. He said he grew up with the 215 and knows it like the back of his hand. fingers crossed
Old June 7th, 2018, 07:22 AM
I've got an E-brock 500 cfm on my 62 and it is not the cause of oil smoke.
joe_padavano is offline
Old June 7th, 2018, 12:55 PM
carbizguy's Avatar
Thanks Joe, yeah I was more concerned the edelbrock may be causing my hesitation and sputtering when it's cold. I read on the HAMB that the 390 cfm was more ideal for this engine. I'm headed to my shop to see if he can get this all sorted out.
Old June 7th, 2018, 12:59 PM
That sounds more like a choke adjustment problem.
Old June 16th, 2018, 10:06 PM
Torqueline's Avatar
Not fired yet, but I have installed a fuel injection system on mine. Also fit a 69 Camaro fuel tank so I could have a wet fuel pump to keep noise down and better fuel delivery.
Torqueline is offline
Old June 25th, 2018, 08:34 PM
carbizguy's Avatar
thats very nice, can't wait to hear how it works out for you
Old July 18th, 2018, 08:35 AM
hotrodsurfer's Avatar
1963 F-85 Cutlass
I just bought a '63 F-85 and am in need of some parts.The letters on the trunk are missing as well as the front fender cutlass script and Olds "'T". any help would be great. Email: surfindudetoo@gmail.com. Thanks
hotrodsurfer is offline
Old July 19th, 2018, 07:57 PM
carbizguy's Avatar
Nice, welcome! Not sure, I will see what I got.
CBennett
May 13th, 2016 04:46 AM
590moss
Non-Olds Engines
December 22nd, 2013 06:08 AM
abillabongbelle
July 9th, 2013 07:27 AM
radman58
August 22nd, 2011 09:35 PM
war eagle
April 8th, 2009 10:01 PM
Quick Reply: Well I bought another 63 F-85
