1961 starfire front emblem bar
Its maybe two feet long or so. I guess you would call it a grille bar for a Starfire or a 98. I just bought mine from Ebay not that long ago. There were two of them at the time from different sellers but I haven't seen one lately.
You might want to run a wanted add on here if you want one. Did you say you wanted it for an F85?
yes , for a custom application , i find this bar more cool than the script under the grill and i would like to use another oldsmobile part otherwise , i think to build custom one . i am going to check on ebay , thanks for all these informations !
Let me know i can take some close up pictures if you need some.
I like the idea the grills are so similar. I'd love to build a gasser style 61 F85 in black.
Could you post a picture of your car?
I hope you can see this shot is between the grill and the radiator with the hood hold down plate removed it shows how the center grill bar is mounted I actually used my two Center Oldsmobile mounts to mount the grill bar but the out side mounts did not line up I will have to modify them slightly.
The bar is 37 in wide roughly by 3 in total depth. Each blade is about an inch and a half wide.
Thanks so much ! i think i should make custom one because the globe emblem is at the place where i must put my hand to pull the mechanism to open the hood but , i am going to look for an og grille bar and get one to check if all is ok or not with the hood .
Thanks again for your help and your time
mr bojangles
Suspension & Handling
February 10th, 2021 06:03 AM
