Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
63 F-85 underhood color & cowl tag decode
Old March 19th, 2017, 03:51 PM
carbizguy's Avatar
I have been doing some research on the correct 63 F-85 under hood paint colors. I've noticed some cars engine compartments were painted the body color and some were satin black. I'm trying to find out which is correct and the only info I found was that Oldsmobile painted the 63's both ways, depending on production date.
Does anyone have further info on this? I just want to make sure which color is correct for my production date. My dads car appears to have original paint and interior, but I can't be certain. It's white on white, which also seems like an uncommon color combo as I can't find any other examples on the internet. So, I wanted to try and verify the cowl tag to see if someone changed anything along the way...
here's the tag, what do you guys think?
carbizguy is offline
Old March 24th, 2017, 04:49 PM
carbizguy's Avatar
Bump, anyone with any info on engine compartment color or the cowl tag?
Old March 24th, 2017, 08:20 PM
young olds's Avatar
All the f85's I've had, the lower body color and engine bays matched. But I've only had 62's
young olds is offline
Old March 24th, 2017, 09:24 PM
1970-W30's Avatar
On my 63 the engine bay matched the body color like it should. Paint code CCC translates to Provincial White top, lower body and wheel color.
1970-W30 is offline
Old March 24th, 2017, 10:32 PM
carbizguy's Avatar
Nice, thanks guys. Now I just need to find out what the 957 trim code means.
Old June 5th, 2017, 08:34 PM
gmiles's Avatar
My 63 Cutlass had a white engine bay, same as the body color.
gmiles is offline
Old June 6th, 2017, 10:16 AM
oaklyss's Avatar
957 decodes as White vinyl interior
oaklyss is offline
Old May 28th, 2018, 11:53 PM
carbizguy's Avatar
thank you
Clipperet
June 10th, 2011 11:48 PM
jon69olds
June 10th, 2011 12:48 PM
67 Delta 88 hardtop
October 4th, 2010 04:41 AM
jdullen
September 10th, 2010 06:05 PM
neller840
July 28th, 2010 05:01 PM
Quick Reply: 63 F-85 underhood color & cowl tag decode
