Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
New member
Old January 5th, 2015, 04:30 PM
luther*omega's Avatar
New member
Hi i am a new member on here. I recently bought a '74 omega and am in the process of dropping in a '70 buick 455. Any advice would be greatly appreciated! Its my first project car
luther*omega is offline
Old January 5th, 2015, 04:47 PM
citcapp's Avatar
Welcome to CO from the left coast
Glad you have you with us. But I do have a question. Why not an Olds 455. A much simpler install then the Buick 455 and you will remain all Olds.
citcapp is offline
Old January 5th, 2015, 04:48 PM
Welcome to the site, I moved this to the non Olds engine section where you might get some help. I would think you would have to treat it like an Apollo.
oldcutlass is online now
Old January 5th, 2015, 10:18 PM
It did have an olds 455 in it but it ended up with a crack in the block so i went with a buick 455 mostly because i couldnt pass up the deal. I like that low end torque it cranks out too. It is a pain getting into the omega only because everything is sorta switched around, fuel pump wiring starter and distributor. Any idea where to get emblems for this omega?
Old January 8th, 2015, 09:29 PM
The_Jeremiah's Avatar
Welcome to the sight! The omegas are not very common, that body style was only produced for 73-74. If you want emblems for the omega keep an eye out on ebay, or start searching wrecking yards. Also you are the boss, but I would sell the buick motor and get an olds motor in it, the oldsmobile community is very serious about the oldsmobile engine, and most of the value is taken away from that car with something other than an olds in it. I am currently building a 455 6 speed omega as we speak! best of luck on your project!
The_Jeremiah is offline
bcracing
July 1st, 2009 07:15 AM
rileyborup
May 25th, 2009 10:35 PM
sean65
December 2nd, 2008 01:26 PM
66442ragtop
April 9th, 2008 02:31 PM
raincitymarc
February 23rd, 2008 08:50 PM
Quick Reply: New member
