Knock Knock when hot 75 pontiac 400 video
Hey
I have a problem, when engine Is hot after 15 min driving i got a Loud knock knock Sound from the engine... Seem that something ob the valvetrain is wrong.
I checked the Rocker Arms and measured compression - everything fine!
Does anybody have an idea!??
Here is a video
Alex
Here is a video
Alex
i tried... its not comming from under the valve cover....
how can i identify a lifter?
also when driving abound with 49 mph its makes a fast not very loud tick tick tick sound ...
i also tied disconnecting each zylinder but does not affect ehe sound in idle ...
i am sure that this is from the engine not from the accessory
i checked under the cover and every rocker arms looks moving correct...
if you are refering to the sound it seems that the knock is komming every 8 th turn... so its comming 1,5 times a second...
which pinthe to be a lifter
my other thought is that it could be a bearing issue like this guy in the video has... but his knock is way mor often then mine ...
so may i should replace all lifters ....
if the sound still appear is must be a crankshaft - rod bearing issue...
so the weekend is over and the engin is running smooth :-)
i replacend the lifters and rocker am studts to go to a adjustable vlave train..
the engine makes no chattering or ticking sounds, more quiet then ever :-)
used this instruction to set valve lash
http://www.boyleworks.com/ta400/psp/rockers.html
thanks
thanks
BangScreech4-4-2
February 25th, 2015 11:18 AM
delta_88_germany
Brakes/Hydraulic Systems
November 2nd, 2013 05:06 AM
