Looking for info on 350/350 swap into 61 olds 88
Okay, I'm just about done with the 394/slim jim. Time to start preparing for the inevitable, the SBC 350/TH350 insert. Anybody else done it? Tips n tricks?
No, I'm not spending a nickel more on trying to keep the heap going. Its my families more-door, so purists back away.
Also looking forward to the front end losing 300 lbs.
I've done it on a 64 88. Just used a big piece of C channel iron for a crossmember and drilled new holes in the frame. I remember the slimjim yoke fitting the th400, but don't remember what we did for a driveshaft. We had a pile of 20 of them out back, and probably just used conversion u joints on something "close enough". It was probably 7 years ago, so i'm a little fuzzy on it. I also remember making custom engine mounts for the frame with the welder. The th350 is going to be really short. I believe we used a th400 with a 9" tailshaft.
not the 60's full sized manifolds with the center dump. The crossover pipe was too short, so we ran dual exhaust from each manifold, and made a block off plate for the crossover hole on the passenger side.
How bad off is the 394? Might end up cheaper/easier to freshen it up and get an adapter to the transmisson of your choice.
http://transmissionadapters.com/Olds_install.htm
The 394 seems fine, 125 psi cold/dry compression test. Has a slight tick, tickier on first start up.
I love SBC, on stand in garage, beggin for a chance to make the olds rock.
Adapter? $1000! no way.
sx455raidercelticfan
August 1st, 2010 08:03 PM
moparmusclecars
September 3rd, 2008 06:15 PM
