Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS No Start
Old April 17th, 2014, 07:31 PM
LS No Start
I have a 67 Cutlass with an LY6/4LE85. The car was running fine last Saturday, parked and did not start Monday afternoon. It will crank, but the fuel pumps, cooling fan, and gauges do not power up. I have switched out relays on the ECM fuse panels also to no avail. The ignition switch passes 12 volts as the accessories (turn signals, wiper, radio, etc are functional. I also used my scan tool and it cannot communicate with the vehicle, it says.
I am not super comfortable poking around, but have removed and re-seated all connectors, etc. I also did not build the car, the previous owner seemed to think the relays were possibly bad.
Any idea of where to start? Could the ECM just die?
Thanks!!!
19sixty5 is offline
Old April 17th, 2014, 07:43 PM
Professur's Avatar
You better believe it. That's why so many of us choose to stay old school
Professur is offline
Old April 17th, 2014, 07:54 PM
John unfortunately you need to find someone familiar with that setup to help you troubleshoot it. You might do a search to find someone on here that has done a swap like yours or perhaps visit one of the LS boards. Most of us old timers wouldn't know where to start.
oldcutlass is offline
Old April 17th, 2014, 08:00 PM
Senior Moment Member
Your car has rejected the transplant! Just kidding. I hope you find your problem. I nearly did one of these for my buddy. We went with a 502 chevy instead.
z11375ss is offline
Old April 17th, 2014, 08:09 PM
+1.
You've angered the gods.
You need to find a "tuner" of riceburners to massage its electrons.
I can help you figure out how to install a carburetor and points ignition on it, though.
MDchanic is offline
Old April 18th, 2014, 04:45 AM
Your gauges are not powered through the ecu, unless the dash from the LY6 was swapped over. You have a voltage feed problem between the ignition and ecu. Could be as simple as your ignition switch. With the key in run start checking for 12V. If the harness is original, all the pink wires should be hot.
Another thing to be aware of is GM cars from the 60s used an ignition switch that fed power to one circuit in run (the ballast resistor) and another while cranking (bypass to the coil). Because of this some LS swaps have some "creative" wiring to get 12V to the ecu in both run and crank.
garys 68&72 is offline
colemane
April 13th, 2013 01:19 PM
Destructor
October 22nd, 2010 05:35 PM
rrielley
September 1st, 2008 03:00 AM
J'ville
June 10th, 2006 03:13 PM
emarkay
December 8th, 2004 08:23 AM
Quick Reply: LS No Start
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
