questionbout 88 camaro
if i drive through a puddle, the steering will lock up andwill only turn a little bit.
it returns to normal after about a minute.
whatcan be causing the lockup
steering gear lock up
Is it in a puddle or just when it gets into a bind? Like hitting a bump or pot hole? Could be the control valve at the top of the steering gear. They have seals that seperate the ports in it. If they are worn it can flow to two directions at the same time. "locking up" There is a check valve in the back of the pump that could be weak too. But, more than likely is the gear valve. Meaning replace the gear.
Hope that helps
Larry
Hope that helps
Larry
Hope that helps
Larry
Hope that helps
Larry
Your power steering belt is loose.
Puddle splashes water onto belt.
Belt slips.
Steering gets tight.
If you do some serious barbell work, you'll stop noticing it when it happens.
Belt slips.
Winnipeg Cutlass
April 17th, 2006 03:15 PM
