Will SBC and tranny clear all at once with crossmember?
My crossmember is welded to my 3 inch dual exhaust so I cannot move it. My question is can I drop the engine and transmission in as 1 unit with the crossmember in place? I have a small Chevy with a turbo 350 transmission, I will be using a cherry picker in my driveway. Thanks for your help.
The way it is done is the crossmember has a big peace of pipe welded into it that the exhaust pipe runs through, and it is also welded through. I am going to add a set of cats on it eventually and at that point I will change the exhaust around a bit. When I did it I did not know that they made a crossmember for dual exhaust, I am going to install one when I change it over.
Del70
September 30th, 2014 07:21 PM
prs1989
December 2nd, 2013 05:24 PM
