1973 Omega Restoration with Pontiac ohc6 sprint
Good morning,
would like to share my project Francis!
When my dad (Franz --> Fancis) passed away 2 years ago the idea come up to build something unique to honor my best friend, adviser, mentor, judge,...
So I started research which car would fit the idea to do nearly everything on my own, does look good, parts are available even for me in Austria. Found the Chevy Nova.
As the project should be ready till my fifties birthday I of course had to go for a 1973 model!
I spent nights in the internet to get myself familiar with the topic (my brother was helpful as well - he is a mechanic), created lists of parts which I would like so use, trashed it because of other ideas and started from scratch. Saw the Chevrolet project with the LTG 2.0 Turbo swap - followed this. But again things came different :-)
Than I found Bruce Kaiser from kaisercarart and asked him to create a draft for my with my ideas and this is the result:
So there will be new disc brakes all around, new front and rear suspension, rebuild of the rear end, very customized interior, some high fidelity audio equipment and nice paint job.
Very long search for the car started - in Austria there is no market, in Europe nearly nothing and if, than the prices are horrible!
Than a view weeks ago I run across an Oldsmobile Omega 1973 in craigslist. A fellow member of stevesnovasite helped me to get in touch with the seller. When I saw the VIN I was clear I have to swith my project from the Nova to the Omega. The VIN ending with 1868 which is the year of birth from my granddad, whom I never met. He became nearly 100, but died years before I was here. His name was like my fathers name Franz.
So I bought the Oldsmobile Omega 1973!
When the seller tried to change the title they discovered that there is still a lien on it. No real issue, it lasts only longer to get it cleared and the shipping to Bremerhaven will be delayed. So he asked me, if I need anything else? So we discussed my project and the idea of the LTG 2.0 turbo. He was laughing. The discussion ended with the result, that we will put a Chevy LM7 engine core into the trunk.
So now Bruce Kaiser is reworking the design and I'm waiting for the Omega to arrive in Europe!
Very nice. I would see if there was anyway that he could send a transmission along with the car as well. An overdrive trans will be much better with what you want to do with the car. And being that close to the Autobahn...yup.
I have a question and you hopefully some advise: the olds omega will never see any track or other racing (at least now not planned) - just a good performing cruiser.
Should I stay with rear leaf springs and sway bar front and rear or go for a 4-link or alternatives?
Front suspension will be upgraded with tubular control arms.
So either Hotchkis Sport Suspension TVS Systems or Ridetech 4-Link bolt on?
Subframe connectors for both?
I personally would go with Hotchkis and subframe connector
before I break down the Omega I would like to drive her and visit some shows and US car events here in Austria.
So I wonder what to do best and maybe give the inline 6 a bit more power?
replace all liquids (engine and transmission oil, brake fluid, coolant)
new spark plugs s and ignition wires
HEI Distributor
brake pads/shoes
fuel filter and oil filter
odometer shows 43596
any other inexpensive performance gains or recommendations to take care of?
HEI Distributor
brake pads/shoes
Just do regular maintenance an enjoy the summer. You wouldnt get much out of it, and even less trying to sell the parts for that Six at Europe;
so if i would be you, id try to attend as many shows i could, keeping the car at sound condition, and save the money to new engine.
Being a 73, I would check brakes/brake lines (especially the rubber hoses), suspension bushings, steering linkage. Anything you replace there will carry over to the final car.
Probably not worth the expense of an HEI if you can just do points/condenser.
HEI Distributor
brake pads/shoes
HEI Distributor
brake pads/shoes
I'll need your advice!
I bought the book “American Cars, 1973-1980, Every Model, Year by Year” and learned that form the Olds Omega 1973 only 26,126 cars and 1974 already with some updates on bumpers and grill 27,075 cars were produced.
The Omega is almost in initial delivery setup and numbers are ok.
So I more and more question myself if this LS swap and all other modification I planned will honor this car as it should do? My oldest daughters opinion is to keep it as original as possible. However in Austria it will be a real rarity on the street. This exact model is therefor listed on the list of worth preserving vintage cars of the Austria federal ministry of transport! And if I will have an Austrian title as a vintage car than anyhow will be forced to keep it in the original conditions.
Than I maybe only will have the S package from 74 installed – lowering the car about 1,5” with the rally suspension and the sport bucket seats.
What would you do?
What would you do?
In the states being that it is a 6 cylinder car its just not that desirable. and as such, not worth a ton of money. I would do the swap and make the car much more fun to drive, and to be quite honest, more reliable.
#32
And the shop will also take care of the bench seats. Unfortunately the forwarding agency lost one of the bucket seats between TX and Germany which I bought here in this forum.
I run across once the TMI sport bench seats and showed it to the upholstery shop owner and he is already very keen to be a bit challenged
Pic from https://www.tmiproducts.com/universal/bench/48-inch
#34
this are 14" and tire selection isn't easy. First I'm not sure if white letter or white strip or just pure black tires.
Second stay with orig. size which would be 195/75R14 or 205/70R14 or go for wider tires?
#37
Hi,
Welcome. You brought back memories, my dad bought a small car in 1973. You know because of the gas crisis in the 70's. He came home with an Oldsmobile Omega. I remember him saying "the sales guy sold me a larger engine because of the A/C. He got the Rocket 350 with the 4bbl. I just grinned since I'd be driving it in less than two years. I found out it had post traction because my sister learning to drive went across the yard and by accident hit the gas vs. the brake and peeled up the lawn to the front steps and bam hit the house! I still remind her of Olds abuse. Good luck with your project and please update this forum as you go.
Guy
Guy
