Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
68 Lemans 350 engine
Old January 13th, 2019, 05:06 PM
72cutlassdog's Avatar
I was wondering if the 68 lemans 350 version with 325 hp came with the 2- speed powerglide tranny or did it come with both 2 or 3 - speed?
72cutlassdog is offline
Old January 14th, 2019, 01:10 PM
GEARMAN69's Avatar
All 1968 350 LeMans and Tempest and Firebirds in 68 both two barrel and four barrel (HO) engines the only automatic was the two speed (ST300) BOP version similar to a PG (same 1.76/1.1 ratio but BOP bell and TH input shaft spline same as TH350/TH400 basically) Only the 400 engine Firebird and GTO got the TH400 besides the B body cars in 68. 1969 was when you could get a 3 spd auto behind a 350
GEARMAN69 is offline
Old January 14th, 2019, 02:28 PM
Just to clarify, other than the fact that it has two speeds and the same gear ratios, the ST300 has exactly nothing in common with the PG. No parts interchange. The Pontiac version was fixed stall speed, not switch pitch. OK, technically, all 68-69 ST300s were fixed stall speed, but the 67-older Pontiac versions were also fixed whereas Buick and Olds used the switch pitch for 64-67.
joe_padavano is offline
Old January 14th, 2019, 03:30 PM
GEARMAN69's Avatar
Joe I said "similar" and just that the ratios were the same and just noted some of the differences and DID answer his question correctly
Old January 14th, 2019, 03:33 PM
I didn't say you were wrong. I was just expanding on the answer.
Old January 14th, 2019, 04:18 PM
GEARMAN69's Avatar
Fair enough ! Cheers ! BTW to all two speed auto trans owners.........swap to a dang TH350 .. its easy and you will love the improved low end power and pep
Old January 14th, 2019, 04:58 PM
Originally Posted by gearman69
swap to a dang th350 .. Its easy and you will love the improved low end power and pep
^^^this!
rktolds
July 26th, 2017 06:51 AM
GEARMAN69
June 9th, 2015 03:05 PM
Rusty wrench
September 12th, 2014 07:12 AM
Jimmy C
May 6th, 2013 05:00 AM
ctrain22
March 9th, 2009 06:11 PM
Quick Reply: 68 Lemans 350 engine
