6.0l lq4
6.0l lq4
Hello olds heads. This upcoming Friday I'm pulling the trigger on a 6.0L LQ4 build from block to turn key.
This engine Ine is going to be going into my 73 Cutlass "S" optioned 442.
I know these engines have been used in earlier model cutlasses and there is modification/aftermarket parts needed for fitment. Which I'm prepared to do to make work.
Im having a hard time finding any 73's out there with these engines in them. My question is is this that much different of a logistical fitment issue then earlier model cutlasses? The last thing I want to do is pay for this build and for whatever reason find out it "can't work".
If anyone hasexperience or knowledge about this swap it would be greatly appreciated. I know that holley makes a retro aftermarket oil pan that will be needed. And I also know the wiring harness will have to be modified. Other than that I'm all ears. Thanks everyone
The GMPP pan should work. It's half the cost and just hangs a little bit lower. Otherwise, logistically, it should fit in the same as the earlier models. Consider headers for these cars are typically model years 68-77 if that says anything about the front frame. Check out G3GM.com. There's a couple guys who have done this already in their 73-77 A bodies.
i have to disagree about the GMPP pan, and doubly so if you ever plan to lower your car. The pan hangs below your engine crossmember making a fragile bit of aluminum your first point of impact if you should ever bottom out. I know the holley pan is pricey but the 302-2 or 302-3 are the only way i would go. Mounts shouldnt be a problem, and as far as exhaust fitment i would recommend searching ls1tech.com for anyone else running a '73-up A body to gain some knowledge from. Best of luck with the build you'll love the results.
