Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS or SBC Swap into 62 Skylark.
Old December 14th, 2017, 04:15 PM
Reebz's Avatar
This is my first post and its not even an Olds question, plus I'm putting the "wrong engine in it" what nerve.
OK guys I have a 62 Skylark (Y Body) similar to the Olds. I want to put a stroker 383 or LS into it.
Does anyone have experience with this? Its going to be a lot of work,cutting but I want to try. Any advice would be great.
Reebz is offline
Old December 16th, 2017, 09:59 AM
Registered car nut
nonhog's Avatar
I sold parts to a local guy with a 350 Chevy powered 63 Cutlass so it can be done. Never saw it (other than pictures)
nonhog is offline
Old December 16th, 2017, 10:22 AM
Reebz's Avatar
Thanks. I think I'm going to replace the cross member and go with a mustang II rack.
Reebz is offline
Old December 16th, 2017, 01:43 PM
garys 68&72's Avatar
Check over at LS1tech conversions forum. Might be something similar there with the LS info.
garys 68&72 is offline
Old December 16th, 2017, 02:52 PM
Reebz's Avatar
Good Idea
Reebz is offline
Old December 16th, 2017, 03:26 PM
Hookers under Hood
76olds's Avatar
Sounds like it will be a fun project! What brings you to an Oldsmobile site?
Eric
76olds is offline
Old December 16th, 2017, 07:48 PM
Reebz's Avatar
Eric
61-63 Y Body Olds and Buicks have the same suspension. Hoping to find some advice.
Reebz is offline
Old December 16th, 2017, 09:44 PM
Hookers under Hood
76olds's Avatar
Post some pics if you get time, Olds or not I like them all.
Cheers
Eric
76olds is offline
Old March 2nd, 2018, 06:08 AM
1971 cutlasssupreme's Avatar
LS power,,, super reliable, great power potential if ya want more, doesn't fill the garage with gas fumes when running,,,, Something else to think about, if its an "only special occasion" driver, the LS is great in that it runs good even after sitting long periods of time. Seems the carburetor/Point ignition systems run better when being used consistently. Obviously its your choice what you want between the frame rails so if you don't mind messing with carb/ignition tune ups ect, go with the old school power.
1971 cutlasssupreme is offline
Old March 2nd, 2018, 06:36 AM
Proud Viet Nam Veteran
redoldsman's Avatar
If I were doing that much work I think I would do the LS.
redoldsman is offline
simpleold
Non-Olds Engines
22
June 17th, 2016 05:13 AM
Johnny Cage
Non-Olds Engines
April 8th, 2013 02:24 PM
kern84
Non-Olds Engines
39
May 27th, 2012 06:54 PM
arnoldjr
September 8th, 2011 07:12 AM
Tony Daytona
January 27th, 2009 07:25 PM
Quick Reply: LS or SBC Swap into 62 Skylark.
