Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS motor swap advice
Old August 23rd, 2017, 12:22 PM
78Cutlass4Speed's Avatar
I've been thinking of an OD trans or rear end gear change for my modified 1979 Hurst/Olds until... another possibility just presented itself. I might have access to an LS2 6.0 motor and auto transmission out of a 2006 GTO with 68K miles. The car was in an accident and hit from behind so there's no damage to the front of the car at all. I can get the motor/trans/harness/computer/pedal/all accessories/ complete for $4800.
Is this a good price?
Is the LS motor from the GTO better than that of, say a Corvette?
Or does it matter?
Will there be enough space for the accessories as is or will I have to make major changes?
I know I'll have to change the oil pan and other things, but is this more hassle than it's worth?
An all aluminum LS2 will definitely take some weight off my front end even though my 455 has Edelbrock heads.
Any thoughts or opinions?
78Cutlass4Speed is offline
Old August 24th, 2017, 06:11 AM
garys 68&72's Avatar
$4800 might be a little high, but mileage is low and the 6.0s are in high deman.
Same motor as a corvette, only accessory drive is different.
Plenty of G body swaps over at LS1tech, you should be able to see if stock accessory mounts will work. If not, Holley makes very nice, reasonably priced mounts. Guessing the AC compressor might have to be moved up.
I love my LS swap, great as a daily driver. Definitely worth it for me.
garys 68&72 is offline
1BOSS83
November 15th, 2013 03:59 AM
1BOSS83
June 21st, 2013 09:58 AM
curvewrecker
May 31st, 2013 09:25 AM
harleyrules
July 1st, 2010 07:19 PM
jessejames
May 27th, 2009 09:25 PM
Quick Reply: LS motor swap advice
