Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
5.3 Truck intake in 71 Cutlass S
Old May 22nd, 2017, 01:45 PM
penutbuter's Avatar
Howdy folks, I am wondering if anyone in here has managed to squeeze a 5.3 with the truck intake into a 68-71 Cutlass and if so what were your obstacles?
I am starting body work so I have a little while until I drop in the motor, but would like to keep as much of the available build budget out of the motor for the time being if at all possible.
Thanks in advance for input.
penutbuter is offline
Old May 22nd, 2017, 02:24 PM
jpc647's Avatar
5.3 truck intake out of what?
jpc647 is offline
Old May 22nd, 2017, 03:27 PM
penutbuter's Avatar
This motor is a 5.3l out of a 2004 Silverado. I have a CTS-V oil pan a friend had laying around.
I don't have mounts or a set back plate yet since I have heard different ones are better for different applications.
Old May 22nd, 2017, 04:10 PM
Isn't the starter on the wrong side of those engines?
Fun71 is offline
Old May 22nd, 2017, 04:25 PM
gbledsoe3's Avatar
The 5.3 is the same base block as the LS engines. Yes the starter is on the passenger side of the LS engines. I have one in my garage on a stand but saving it for my 93 Silverado sometime in the future. I suspect the truck intake will be too tall for a Cutlass.
gbledsoe3 is offline
Old May 24th, 2017, 05:31 AM
garys 68&72's Avatar
Over at LS1tech, there are some A bodies using the truck intake, so it will probably fit. When I put a 5.3 in my 72, I used an LS1 intake because it looked close....and they look better.
garys 68&72 is offline
Old May 24th, 2017, 05:54 AM
csouth's Avatar
It will fit... I have seen some Cutlass' with them installed. LS2 intakes are cheap now though, why not swap? Lots of people with stock LS2 intakes have switch to FAST or another aftermarket intake, so there are plenty to be found.
csouth is offline
Old May 24th, 2017, 12:43 PM
penutbuter's Avatar
I have seen a bunch floating around on ebay and even a few in the NW on CL and offerup. But they are all going for around $200-300 which I would rather put into suspension parts, a 4l60e or sheet metal at the moment. Plus my intake is from an 02 and has the regulator fuel rail.
If I can make it work for a year or two then I can have that little more to put into the car and get her on the road sooner than later. Once I build up the coffers after the resto I will look at picking up a good intake and cam.
Old May 24th, 2017, 01:03 PM
csouth's Avatar
Totally understand.... I always look before I actually need, because I usually find better deals when I'm not pressed for the part... If you were near me $200 could get you an LS2 intake with rails and TB ....
csouth is offline
Old May 24th, 2017, 01:13 PM
With an 04, cathedral ports, 3 bolt TB, you would need an LS1 or LS6 intake. The LS2 is a 4 bolt TB.
I got my LS1 intake for $35 back when they were plentiful. Actually got 2 at $35 each. But even with that, you may need new injectors and fuel rail. That adds up.
Use the truck intake and shave off some of the mounts on top to clean it up, make it look better.
Old May 24th, 2017, 01:39 PM
penutbuter's Avatar
Yeah, when I was in TX and had people around that I knew I could get some good deals but up in WA it's apparently much more difficult.
Yeah, I was thinking about doing the shave mod agearheadforlife did where he relocated the sensors and stuff to the back and side of the intake and shaved the top smooth. I don't know that I will move everything but I will definitely get rid of all the cover risers and bolt bosses
I appreciate all the input. Hopefully I can start getting my build on track and get some pictures up.
Old May 25th, 2017, 09:15 PM
csouth's Avatar
Could use a truck TB with 3 bolt tb to 4 bolt intake adapter.
csouth is offline
Old May 30th, 2017, 06:52 AM
Photoshop God
DewChugr's Avatar
How about the TBSS/new truck intake. It performs very well.
DewChugr is offline
Old May 30th, 2017, 09:10 AM
penutbuter's Avatar
I don't know about the TBSS intake, but I think the new truck intake is rectangle port instead of cathedral. I may be wrong though.
Old May 31st, 2017, 06:47 AM
Photoshop God
DewChugr's Avatar
The TBSS/Rainier is cathedral for sure, they come with the 243/799 heads, there is one in my shed. The 07 and up truck 5.3 has the same intakes as far as I know. I believe the square ports are 6.0 and larger.
DewChugr is offline
65B01Delta
September 2nd, 2013 09:16 AM
svnt442
July 17th, 2011 04:43 PM
Alb
July 1st, 2010 11:10 AM
dhartley72
March 19th, 2010 03:51 AM
87CUTTY
May 1st, 2007 11:55 AM
Quick Reply: 5.3 Truck intake in 71 Cutlass S
