Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Manual transmission swap
Old May 21st, 2017, 01:06 AM
JuliusH05@gmail.com's Avatar
Cool Manual transmission swap
I have a 67 Cutlass and I want to add a manual transmission to it. I already have the console for it
I'm adding an LS to it and want either a 5 or 6 spd. Has anyone done this swap and know what transmission will work with the factory console? It's important that I'm able to use the console that came with it.
JuliusH05@gmail.com is offline
Old May 21st, 2017, 07:10 AM
svnt442's Avatar
If you put a 6 speed in it you will be cutting the floor up to make it fit and I don't know if you will be able to use the console after that or not.
svnt442 is offline
Old May 21st, 2017, 07:31 AM
I need to replace the floors anyway, so that's fine. I seen a 65 Cutlass that had a 5spd
conversion in it, but didn't see who the owner was. I wanted to ask him some questions on it. He was still using his factory console.
Old May 24th, 2017, 05:35 AM
garys 68&72's Avatar
T56 will require floor cutting, not sure if the contour will fit the console. A Richmond 5 or 6 speed will fit without mods. I believe the tremec 5 speed only requires minor mods.
I'm running a T10 behind the 5.3LS in my 72.
garys 68&72 is online now
Old May 24th, 2017, 07:29 PM
[QUOTE=garys 68&72;1017473]T56 will require floor cutting, not sure if the contour will fit the console. A Richmond 5 or 6 speed will fit without mods. I believe the tremec 5 speed only requires minor mods.
I'm running a T10
Isnt the T10 a 4 spd? 🤔🤔🤔 I wasn't aware the Richmond would fit without mods. Gonna contact them in the morning. Thanks
Old May 25th, 2017, 08:11 AM
Yep, running a T10 behind a 5.3LS in my Olds. Also running a Richmond 6 speed behind a 6.0LS in my 68 corvette.
The Richmond 6 speed is great, but no longer available. They still do sell the 5 speed OD trans though. It's pretty much a direct swap for a Muncie/T10. Only crossmember/trans mount changes needed.
Old May 25th, 2017, 08:32 AM
61Bat's Avatar
Most of the modern transmissions that use internal rail type shifters like the Tremec have multiple shifter location options. I had a TKO in my 69 GTO and I was able to use the stock shifter no problem. I believe there were 5 different positions you could use to move it fore and aft.
That said I did have to modify the stock floor pan hump to clear the larger case of the transmission.
61Bat is offline
Old May 30th, 2017, 05:59 AM
Tr
Thanks for the info. I thought you could move it to suit needs. I just wanted to make sure I am able to use this factory console. Was pretty expensive and nice looking, so important to my build
Boldsmobile
December 13th, 2015 07:16 PM
Chris Schoff
June 26th, 2013 03:07 AM
Wyze
Brakes/Hydraulic Systems
January 9th, 2011 12:19 PM
slodat
August 20th, 2010 10:01 AM
Eightupman
January 6th, 2010 03:14 AM
Quick Reply: Manual transmission swap
