⁴g high idle cam
⁴g high idle cam
My high idle cam sticks and does not drop down with engine warm. Does it only rely on gravity to drop it? I have cleaned it, lightly sanded the side, tried it dry and with oil. Just touch it with throttle open and it drops. Any ideas?
I know the choke linkage lifts the cam when it closes, then as the linkage drops, the cam should drop as the choke opens. So there is no spring or mechanical connection that moves it as the choke opens? I have tried it dry and oiled. I guess I will remove cam again, clean maybe try silicone spray.
dancutlass
August 21st, 2012 06:26 PM
73rocketship
July 6th, 2012 06:45 AM
