left hand side mirror?? `64/98
Hi and welcome, you need to check out Fusick automotive products inc and download his catalog www.fusick.com, they carry all kinds of parts we need for the big cars.
Steve
Steve
The factory did not offer a passenger-side outside mirror in 1964. Fusick P/N SM6308B is a reproduction of the factory driver's side outside mirror (non-remote). It might work on the passenger side, but I cannot say for sure. It does have the V-notch in the base to sit on the fender peak.
Which unfortunately doesn't help with the OP's question, as the 62 mirrors are completely different from the 63-64 mirrors. The latter sit on the peak of the fender and have a "V" cut into the base. I don't know if the "V" is symmetric or canted to one side.
Well, as for "peaks" and "v's," here is how the 62 mirror mounts. It caused no problems when I mounted an outside mirror on the passenger side of the car.
If you are lucky and the left and right are the same don't mount it where it looks (measures) like the left is mounted. Most likely you won't be able to adjust it to see correctly behind the car.Test the position first using masking tape to hold it before you drill and attach it permanently....Tedd
The offset on the base of the 63/64 is minimal and you can use the left hand non remote mirror on the right side and get away with it. I can get the measurements for the drilled holes on the front passenger door as I have the original paperwork for the install here, not sure where but I still have it.
Steve
Steve
That's also a non-Starfire remote LH mirror mounted on a Starfire. Lot of difference in remote mirror installations on those. Even the peak moldings for fender and door are different due to the mirror mounting and cable holes.
Two holes for mounting studs and a larger hole for the cable, no pocket that I've ever seen. Before I learned the value of a parts book I bought a NOS 63-64 remote mirror only to find it would in no shape form or fashion mount to the molding on the car. Expensive lesson learned.
October 16th, 2013 05:35 PM
