Speed control throttle sensor
Old August 1st, 2014, 12:21 PM
STELLA67's Avatar
I am in need of some info on the what I am calling the spend control sensor. Mine broke and now my throttle and pedal will not work. Does anyone know what the part# or where I can get this?
STELLA67 is offline
Old August 2nd, 2014, 05:54 AM
STELLA67's Avatar
Ok looks like I'm looking for a switch pitch torque converter switch. I have the GM # and Delco below. Anyone know where these might be sitting?
STELLA67 is offline
Old August 2nd, 2014, 05:55 AM
STELLA67's Avatar
Here is the gm#
STELLA67 is offline
Old August 2nd, 2014, 06:07 AM
Octania's Avatar
What are the symptoms that make you think this pat is bad?
I have heard they can get carboned up inside and fail in interesting ways. If you can't find a new or good used one, maybe yours can be opened, fixed, and re-sealed.
Octania is offline
Old August 2nd, 2014, 06:42 AM
STELLA67's Avatar
Look at the first picture it is completely broke off at the bottom making my gas pedal useless .
STELLA67 is offline
Old August 2nd, 2014, 06:44 AM
I don't see anything broken.
Perhaps you should take a clearer picture.
MDchanic is offline
Old August 2nd, 2014, 06:51 AM
STELLA67's Avatar
I am not where I can take a picture right now and it is on the make of the firewall behind the engine. But if you look at the picture you can see the fresh metal and two bolt holes where the metal casing went all the way around the switch. with out it secure to that bracket it will not properly pull the throttle rod back.
STELLA67 is offline
defiant1
February 4th, 2020 08:53 PM
Joe.S
October 26th, 2012 02:28 PM
cniguy
November 3rd, 2011 01:45 AM
salisbury99
July 5th, 2008 05:26 PM
beebee007
Aurora
August 17th, 2006 06:45 PM
Quick Reply: Speed control throttle sensor
