Rear end problem, need rpo help!
Old July 4th, 2014, 06:47 PM
GStr33tXpr3ss's Avatar
Hello all. I have an '83 Olds 98 Regency Brougham that after driving for a while the rear end binds during low speed turning. From what I know, Lsd/posi cars will do that when the diff fluid has gotten old or there is no or not enough friction additive in there. The problem is that I have no idea what rear end I have. No rpo sticker, apperently they became the norm for '84 on. Can someone please decode my vin because all of the online lookup produce a basic vin decode or nothing.
Thanx in advance.
GStr33tXpr3ss is offline
Old July 4th, 2014, 06:50 PM
Sorry, I forgot to add my vin:
1G3AW69Y5DM785130
Thanx again.
Old July 5th, 2014, 06:38 AM
Thanx in advance.
There is no information in the VIN that will tell you anything about the rear axle.
joe_padavano is offline
Old July 5th, 2014, 06:57 AM
I had a 1983 Ninety Eight Regency Brougham that developed this exact same issue. IIRC there wasn't a tag on the diff either. Lift the entire back end of the car and spin the tires. If they both spin the same direction you have limited slip. Just based on your description of the problem, you have LS though.
Change out the fluid (I'd use conventional 80/90) and a bottle of additive. Put the additive in about 1/2 way through the fluid change. The problem should go away right away.
Allan R is offline
350TurBRO
September 12th, 2014 11:52 AM
Danny Boy
November 22nd, 2012 02:52 PM
1970cs
August 11th, 2012 07:38 AM
mmurphy77
May 10th, 2011 08:20 PM
The Stickman
November 28th, 2008 05:13 PM
Quick Reply: Rear end problem, need rpo help!
