Cruise control turn signal lever
Old May 3rd, 2014, 08:34 PM
w31man's Avatar
I am looking for the correct cruise control turn signal lever for my 1973 olds 98 recency, there are 2 of them on ebay they both look exactly the same except the arrow and writing pointing to the cruise button. One is part#408847 the other is 412342, does anyone know why these are different or if the both will work for my application?
http://www.ebay.com/itm/131178958648...%3AMEBIDX%3AIT
http://www.ebay.com/itm/400703761479...%3AMEBIDX%3AIT
Thanks Greg
w31man is offline
Old May 4th, 2014, 12:30 PM
stevengerard's Avatar
I do believe the older version has the lettering colored black but I do not think that stye was available until 1971 - if you have a screw in type both of these should work. I'd be going with the cheaper one, you can find these in good used condition as well.
stevengerard is offline
Old May 4th, 2014, 01:57 PM
Mr Shifty Sidney's Avatar
From gmpartswiki.com
408847 was replaced by 412342
71-72 98, Toro application
This info was from parts book dated 1/72
My parts book from 11/79
40847
73 All C, E, opt. K30 and N37.
It also listed applications above
Hope this helps,
Don W
Mr Shifty Sidney is online now
Old May 4th, 2014, 08:07 PM
w31man's Avatar
40847
Hope this helps,
Don W
Thanks for your input both of you! I assumed if they looked the same on the ends it would work just wanted a second opinion
Greg
w31man is offline
costpenn
June 24th, 2015 10:38 PM
BeenThere
December 2nd, 2014 08:29 PM
kplange
April 18th, 2012 02:27 PM
DeltaDevil88
May 29th, 2011 09:32 AM
MarkS
July 8th, 2008 04:06 AM
Quick Reply: Cruise control turn signal lever
