69 98 rear seat vanity light not working. No power at the lead . What should I check?
Actually what happened was the power lead was cut and stuck somewhere in the seat when I had it reupholstered. Ran a new lead and everything is working. Only works with key in as I think it should. Thanks so much for your reply.
The light should always come on when you open the vanity door and tilt the mirror door. Having the key in or in the on position should not make a difference. It works without the key from the factory.
