1966 98 Gas Tank??
Old July 24th, 2018, 03:26 PM
mratke's Avatar
1966 98 Gas Tank??
Trying to locate a gas tank for a 1966 98. Is the tank the same as an 88 or Buick or Pontiac? Keep coming up empty on this one. I own a NAPA auto parts and cannot get one for a 98. Can get new ones for F85 and Cutlass. Have exhausted all the searches I can think of.
mratke is offline
Old July 24th, 2018, 08:24 PM
jaunty75's Avatar
Fuel tanks for this era of full-size Oldsmobiles are not reproduced. At least, I've never found one, and I have a '67 Delta 88 which I've owned for 9 years now. Your only choices are to have yours repaired if possible or find good used. I don't believe tanks from any other GM model would work without modifications. Tanks from any full-size Olds that year (Jetstar 88, Dynamic 88, Delta 88, Starfire, or 98) should work.
jaunty75 is offline
Old March 14th, 2019, 02:41 PM
2 '66 98's
bigoldscruiser's Avatar
A friend of mine needed a tank for a 1966 98 convert several years back and had to resort to having a stainless tank built. Rather pricey!!
bigoldscruiser is offline
Old March 17th, 2019, 12:24 PM
Phantom Phixer
Charlie Jones's Avatar
You are correct in that tanks from other makes will not fit .
However , 98 tanks are all by themselves . No other series tank will work .
According to the parts book .
The GM part number is 393003 .
Charlie Jones is offline
willypsilon
Ninety-Eight
December 3rd, 2014 01:38 AM
Canadian Delta
August 17th, 2008 04:33 PM
Canadian Delta
August 13th, 2008 12:08 AM
JoshF85
October 20th, 2005 12:40 PM
Jake Lydey
May 16th, 2005 06:52 AM
Quick Reply: 1966 98 Gas Tank??
