Fuel pump
Fuel pump
Hello - looking for some advice...I am currently building a 68 442 convertible. The engine is a 69, 455, bored 30 over, mild cam. Should I use a stock manual fuel pump or an electric one? It does have an HEI distributor.... Stock Quadrajet carb....
Stock pump says 30 gph under pressure per rob web page.
1/4 mile in oh 15s let's estimate.
At 30 g/hr, and 0.0042 hrs/ race, that's only 0.125 gallons per race of delivery capability. A pint seems like maybe not enough to do that.
Depends on the car and whatnot I guess.
The rob pump appears to flow about 2x as much in general.
It does not say, but one assumes that the flow numbers were produced with a stationary lab setup, w/o the effects of sucking the fuel forward from a tank located 16 ft aft of the pump... against the effects of vigorous acceleration.
Check this one at Supercars Unlimited to see if it fits your application.
For around $20, Rockauto has a Carter pump.
http://www.rockauto.com/catalog/x,ca...,parttype,6256
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
