1969 442 key cylinder switch
Old February 20th, 2015, 10:21 PM
ajavila's Avatar
I believe the plastic shaft that pulls the teeth on the rail is broken I need a pic of one and how to replace it , do I have to remove steering wheel to replace that? ......the old key cylinder was pulled out before car was purchased .thanks for any help
ajavila is offline
Old February 21st, 2015, 05:25 AM
mrolds69's Avatar
That's called the sector gear. I think if the cylinder is out, you can pull it out with needle nose pliers, I'm not positive. If the cylinder is in, the wheel has to come off. Let me look for a pic.
mrolds69 is offline
Old February 23rd, 2015, 12:04 PM
mpolds's Avatar
Letter Coded *** GM *** Ignition Tumbler
If you would like a NEW Ignition Tumbler & keys:
I have two versions of aftermarket (different price)
and 1 last Letter Coded for '69 *** GM *** Ignition Tumbler with keys!!!!!
mpolds is online now
louie
July 9th, 2014 01:10 PM
mmurphy77
December 9th, 2011 08:31 PM
86ChebbyWagon307
July 5th, 2011 07:09 PM
knighthawk
January 11th, 2011 03:55 PM
Quick Reply: 1969 442 key cylinder switch
