1940 2 dr. sedan series 60
Old July 22nd, 2014, 08:40 PM
fairdeang's Avatar
I have a 1940 Olds 2dr series 60 sedan that I am restoring body to street rod. I would appreciate any advice to convert the rear suspension to more modern technology. I already have a plan to use chevelle/cutlass upper fr. control arms and modify the lower, will use either 2" drop s-10 or chevelle spindle and discs. Want to move the rear axle back 1.5 inches-may mini tub- would like to make all gm/olds. the flat original six, 3 sp. trans and rear is available for purchase and runs good.
fairdeang is offline
Old July 22nd, 2014, 08:51 PM
47 Convertible's Avatar
Welcome, sounds like you have a plan for the 40. Over in the various forums under car models you will find Vintage Oldsmobiles and like minded people though I don't recall any other 40 owners, there may be. I'll be looking forward to photos and hearing more about front and rear suspension plans. Front suspension plan is intriguing and I don't recall ever seeing or hearing about one so modified. Lots of good tech advice on other parts of the site.
Jerry
47 Convertible is offline
Old July 22nd, 2014, 09:14 PM
64Rocket's Avatar
Have you thought about a frame swap?
I have a '50 Olds coupe and swapping the frame from a '67 Olds Vista cruiser to put under my coupe. keeping it Oldsmobile power, just a little newer.
More modern suspension and lower ride.
It is a work in progress now, should be done in a couple of months.
I'm going to start a thread on the swap, be on the look out.
Give it some thought, a GM frame with same wheel base.
Gene
64Rocket is offline
Old July 23rd, 2014, 06:44 AM
Tedd Thompson's Avatar
Welcome aboard and as mentioned above drop on down to the vintage forum and introduce your self there . They have an ongoing thread that is all about the early pre and post war Olds I'm sure they can give you some good advise.....Tedd
Tedd Thompson is offline
Funkwagon455
July 8th, 2014 10:33 AM
1970cs
June 13th, 2012 06:29 AM
Schools001
May 26th, 2012 01:22 PM
okie88
December 15th, 2011 11:01 AM
deaddds
December 26th, 2009 06:16 AM
Quick Reply: 1940 2 dr. sedan series 60
