70 cutlass ragtop dual exhaust upgrade
Old February 26th, 2014, 06:44 PM
gino312's Avatar
Greetings to all from a newbie
-replacing single exhaust w/ flow tech headers and Thrush turbo dual muffler kit
-replacing std rear end w/ 442 dual cut out bumper
-adding 442 tips
-350 4bbl stock engine is the motor I have in the cutlass.
Q-Any issues/advice on adding new headers to std Cutlass underside?
Q-Which tips/flutes would you recommend for an "original" 442 look? Pypes 442 exhaust tips are what I want to buy. Any opinions?
Great site. I appreciate any/all opinions.
Gino
gino312 is offline
Old February 26th, 2014, 06:51 PM
Headers are fine if you like them, but they have tight clearance on the starter and oil dip tube. That makes them a PITA to install. If you want to keep the stock exhaust manifold, there's a blockoff plate that can be bolted in to the driver's side crossover to make it into an N10 (factory option) exhaust. I've heard pros and cons of exhaust leaks with headers so it's a personal call.
You shouldn't have any problems with the rear bumper or trumpet exhaust tips. Most shops nowadays will sell them and install for you while the car is on the hoist. Pypes is a popular brand. Stainless steel of course. They need a special hanger to center the exhaust in the bumper.
Make sure the bumper is fitted right (gaps: top and side) before you do the exhaust.
Good luck with your project. Take pics before, during and after, then post them here for us to admire??
Allan R is offline
Old February 26th, 2014, 07:55 PM
GM Enthusiast
OLD SKL 69's Avatar
Welcome to CO! Allan already gave you great advice on the exhaust/bumper, so I'll just add that add that we like pictures here so post some pics of your ride when you get a chance.
OLD SKL 69 is offline
Old February 26th, 2014, 08:20 PM
Welcome, x3 on pictures.
oldcutlass is offline
Old February 27th, 2014, 07:05 AM
Past Administrator
Oldsguy's Avatar
Welcome to CO, not sure about this but you may have to get a dual hump transmission brace to make room for the second exhaust pipe. I know that later Cutlass models did not have it standard.
Oldsguy is offline
Old February 27th, 2014, 08:39 AM
455man's Avatar
For the headers you will have to remove the starter and oil filter housing on the block. Dipstick tube has to come out and it's a pain to get out.
455man is offline
Old February 27th, 2014, 08:49 AM
Beer Connoisseur
70cutty's Avatar
X2. Might as well buy a new dipstick cause the original is PIA to pull out and most likely it will break.
70cutty is offline
Old February 27th, 2014, 09:16 AM
I bought a new tube for mine about 5 years ago and I had to scour the country to get it. The correct one has been discontinued for a LONG time.
From Chris Witt's excellent part numbers database:
401567 - "INDICATOR, engine oil level [dipstick] , 20-5/8"" [short type]
Olds 68 (Late) - 73 350 & all small blocks exc. Toronado
Mates Guide Tube #401568 = 14.8"" OAL/9.66"" top part"
I think you can easily find a later year replacement tube, but it has to be used with the correct matching indicator, and they will be longer than the originals.
I made sure that my correct replacement 401568 tube would survive by sanding down the "bump" so it was a slip-fit and then wrapping Teflon tape around it so it fit snugly. Now anytime I want to remove the tube, I just pull on it and it comes out easily.
Fun71 is offline
Old February 27th, 2014, 05:41 PM
Dan, the 68 - 72 models have the dual hump brace so it shouldn't be an issue.
Allan R is offline
Old February 27th, 2014, 07:30 PM
I like headers and the headaches of having them. Periodically you have to change the gaskets and tighten the bolts, but that's hotrodding.
Old February 27th, 2014, 09:39 PM
That must depend upon the brand of headers. I haven't touched bolts or gaskets on mine since the last time I had them off, and that's been so many years I can't remember how long it's been. 8-10 years probably.
Fun71 is offline
Old February 28th, 2014, 06:50 AM
A couple of tips.
First, use a slide hammer to remove the dipstick tube. I made an adapter for my slide hammer that is simply two bolts welded head-to-head. One screws into the slide hammer, the other is a slip fit into the end of the dipstick tube. Slide it into the tube and clamp with a vice grip on the outside of the tube (use electrical tape to protect the tube if you care).
Second, use embossed copper header gaskets.
Third, get a quick disconnect starter harness (like the one Moroso sells) to make your life easier. While the starter is out, you MIGHTASWELL replace the solenoid, brushes, and starter driver.
Fourth, be very careful when reinstalling the dipstick tube. You should only apply pressure above the bead that seats against the block. There's a special factory tool to do this, but some people have had success using an open end wrench that's exactly the right size and hammering on the wrench.
joe_padavano is offline
Old February 28th, 2014, 07:40 AM
71 cutlass convertible
lshlsh2's Avatar
Something to think on with a convertible. A loud exhaust in a closed car becomes very loud with the top down. Then becomes a real headache when you take the family to the beach at 70 mph for 2-3 hours.
Larry
lshlsh2 is offline
Old February 28th, 2014, 08:45 AM
gino312's Avatar
Thanks to all for the detailed replies....what a brotherhood.
Yeah, I wanted more HP on a limited basis. I'm not a noise guy at all. Rumble, not grumble, right? So, the comments re- convertibles and dualie noise output are near and dear to me.
We'll see on the outcome. Keep the comments coming. As I find a few more dollares, I will hit you guys up for upcoming work like a new top to replace the duck tape and 30 yr old top. Thx all. gino
gino312 is offline
Old February 28th, 2014, 09:47 AM
hookem horns's Avatar
I have the same except Hedmann headers on a '69 vert. Not too loud in my opinion (better than Flowmasters or glasspacks) but I have set off a 'vettes car alarm in a parking garage. Hard to describe, but seems quieter with the top down since the sound escapes rather than resonates off the roof, or maybe it's just the wind drowning it out. Headers may not make that much of a performance gain on stock 350, so consider duals off the factory manifolds if concerned about the sound.
hookem horns is offline
Old February 28th, 2014, 12:15 PM
If you really care about sound, I would strongly recommend Walker Dynomax turbo mufflers. Authoritative without being annoying.
Old February 28th, 2014, 02:23 PM
If you're interested in the original sound, no one makes a better system than Gardner. My best buddy just restored a 69 442 vert and used their system. He recommends it highly, and he does concourse restos. Gardner is not cheap, but most comparable exhausts nowadays aren't either. I believe Gardner also offers SS.
Allan R is offline
Old February 28th, 2014, 02:30 PM
kattotonic's Avatar
Welcome! I was thinking of going dual glasspacks on my 73' but I don't want to get into changing the headers, even without doing that it sounds like a bit of work lol Maybe just one is good enough And the noise would not bother me, I drove aircooled VW's for years, talk about not hearing after a long trip lol
kattotonic is offline
Old February 28th, 2014, 02:35 PM
Shaking out the cobwebs..
midrange's Avatar
I have these on my 'vert and love them. I don't have any problems with the dreaded drone that other mufflers have with the top up, or being loud with the top down.
Any sound that we do hear is muffled from wind noise while driving.
And they sound awesome when your right foot lays into the pedal....
midrange is offline
Old February 28th, 2014, 02:38 PM
Hookers under Hood
76olds's Avatar
Welcome headers are great , shorty hedmans are nice n easy. but long tubes can give it a little more, Pics would be nice !!
76olds is offline
1Fastolds
Ninety-Eight
June 9th, 2014 09:12 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
aaronlife
August 30th, 2010 09:51 AM
Ron King
January 11th, 2010 05:23 AM
Quick Reply: 70 cutlass ragtop dual exhaust upgrade
