Vin Decoder
or
Login with Facebook
Gas pedal removal?
The place where you should introduce yourself. Do not ask technical questions here, use the site forum sections.
Gas pedal removal?
June 4th, 2013, 06:08 PM
R8der4life
Gas pedal removal?
I have a 1964 jetstar88 and am trying to install new carpet. Is there a trick to remove the gas pedal from the floor board? Please help.
R8der4life
Find More Posts by R8der4life
June 4th, 2013, 06:51 PM
Oldsmaniac
You pry it at the bottom. There are 2 ball headed bolts. The gas pedal is pressed onto the *****. Some WD 40 helps.
Oldsmaniac
Find More Posts by Oldsmaniac
gas pedal ball studs ('65 cutlass)
slowolds
July 21st, 2010
02:31 AM
Lights get brighter and dimmer with gas pedal push
Gaz Hog
June 25th, 2010
04:13 AM
Need Information - Gas Pedal Retainer Bushing
My442
May 2nd, 2010
04:24 AM
NOS gas pedal, big cars
jensenracing77
February 7th, 2010
05:30 AM
HELP! Gas pedal removal
64starfire
June 12th, 2009
07:43 AM
flexplate problem
Posting Quick Reply - Please Wait
Quick Reply:
Gas pedal removal?
The following errors occurred with your submission
Okay
Quote message in reply?
11:09 AM
