New member help rocket build
I have a oldsmobile 350 rocket gold engine came out of like a 75 olds tornado complete rebuilt bored .040 complete valve job new guides upgrades spings to match with new mild steet comp cam new timing chain I mean the works. My engine just isnt giving me the power I think it should have and i believe it has alot to do with my timing/tuning I wana know wat is the best way to find your best timing for you engine and i do have a distributor with the curve kit also any help provided is greatly need!
Im not exactly sure wat it came out of im just goin on wat the guy said i got the engine from and im sure its around those years because when i bought the arp head bolts at first i had to the wrong ones "the smaller ones" and I was informed then that a i had a early 70's model motor
In fact, the Toronado never came with a 350 in any year
Welcome to CO. If it came out of a Toronado, it is either a 79 or 80 engine. As far as your problem goes, can you give us more specifics on your fuel/ignition setup? Stock HEI setups are generally not geared for performance and if yours is stock, that would be one of the first places I would look to modify.
wildwillie1981
April 24th, 2013 04:19 PM
66442ragtop
April 9th, 2008 02:31 PM
