67 Toronado and 455 engine block question?
Hello, I'm new in town and have a 67 Toronado (My original first car from my teens) and just purchased a 54 Hudson Hornet (4 door) with what I'm pretty sure is a 455 Olds motor.
The block number is N668482 and was wondering if someone could direct me to a website to identify the motor?
There is a slim chance that it's not an Olds but from all info I have and a couple old hot rod eyeballs that seems to be the consensus.
Any help is appreciated.
Thanks, Barry
tubb@mac.com
Thanks, Barry
tubb@mac.com
Welcome to the site Barry! Those numbers don't sound familiar to me, but here's a thread showing where to located the casting number and if the engine is 1968 or newer where the vin would be stamped. If this doesn't answer your question could you post some pictures for us?
https://classicoldsmobile.com/forums...s-engines.html
John
John
A photo of the motor would remove all doubt.
A 455 in a Hudson Hornet sounds pretty cool, though... I'd keep it just like that (well, maybe channel it onto a Jag XK16 chassis... ).
Berry welcome aboard
Like the others have said a picture is worth a thousand words.
I'm an old Hudson fan with 53's being my old high school car. A Hudson with a 455, what a sleeper thats gotta be loaded with a bunch of the cool factor, wished I could have done that in high school. ....Tedd
Sorry, Eric, but that's a rookie mistake. The 1966 Olds Qjets used the side inlet. The carb in the picture appears to be a correct 1966 Olds setup, including the divorced choke on the intake. That makes the intake and carb, anyway, a 1966 piece, and I suspect the whole motor is a 1966 425.
I meant to add to my prior post that you should locate and tell us the BLOCK casting number, located above the water pump, next to the oil fill tube. That will confirm what block you have.
I also like the, ah, creative t-stat bypass and heater hose routing on the water pump.
That would be one of those early QJets with the round-stamped unit number and the funky diaphragm needle and seat, then, no?
'67's used the side fuel inlet and divorced choke also.
TimKillinger
May 31st, 2012 09:32 AM
ut442
March 9th, 2012 11:57 AM
