low oil pressure 63 215
Need some advice just rebuilt entire engine and can't get oil pressure back to where it was (30 lbs) before the rebuild. Here is the series of events
Block was honed, new camshaft bearings, heads refrubished, new freezeplugs.
New cam, new rod and main bearings, new piston rings.
new camshaft had a "painted surface on the lobes and bearing surfaces that the machine shop told me was OK to assemble that way.
Put it all together and started it up. Oil pressure went to 30 then dropped to 20 at idle. Drove car around to seat the rings and pressure continued to drop to 20 under full acceleration. Parked car for the night and next day started it and the pressure gauge spiked at 80 then dropped to 30. Changed oil and filter (10W30). Pressure again 30 when cold dropped to 18 when hot and about 22 under acceleration. Changed oil and filter again (10W30) same results. Engine runs very smooth, no noise just no pressure, changed oil again to 10W40 still the same. I am using a Stewart Warner mechanical gauge, I blew out the plastic line to make sure it wasn't clogged. Question, could the oil pickup tube be clogged from the painted surface on the cam, can this be reverse flushed without taking off the pan. Will a High Volume Oil pump solve the problem? Forgot, I also took out the pressure relief valve and cleaned that area, the valve had alot of scratches on it. Help, need advice!
More checking is needed
A bit of an unknown
I am uncertain. Usually when a part is unused, I would not expect to find the scratches. When it gets the scratches during use it's often due to some abrasive crud or a burr on an adjacent piece which it touches during operation. I suppose the question now becomes do the scratches (or the cause of scratches) interfere with the valve performing it's job or not. I suppose that a close inspection with attention to functionality would be a good thing. Best wishes.
olds70supreme
December 29th, 2011 06:21 AM
