Best after market replacement water pump
Old August 22nd, 2010, 12:14 PM
tomc's Avatar
Hey guys new to the site and have question regarding best aftermarket water pump for non radiator cowl, 4 speed, non a/c, bench seat W30. The best that I can come up with it should have came with 404584 water pump, hd cooling or w30. Currently has a pump from 73 or 74 455 and a non clutch fan. Runs hot in warm weather which I believe is because of the incorrect pump and 5 blade fan. The current set was on the car when I purchased it. Have managed to find what I believe to be a correct fan. 19" six blade clutch fan marked ERX. Not looking to take cheapest way out. Want a high quality, reliable, good cooling pump. Any feedback would be appreciated. Thank you
tomc is offline
Old August 22nd, 2010, 02:31 PM
Past Administrator
Oldsguy's Avatar
I can't recommend a specific part for the pump for you but I think that 6 blade clutched fan will make a noticeable difference for the better. Welcome to CO.
Oldsguy is offline
J-(Chicago)
March 31st, 2013 02:38 PM
Big John 85
March 30th, 2009 06:32 AM
tim72
March 25th, 2009 10:28 AM
tim72
Body work
February 28th, 2009 08:37 AM
citcapp
January 6th, 2009 08:33 PM
Quick Reply: Best after market replacement water pump
