Where is the engine number located
Old March 1st, 2010, 08:45 AM
skip79's Avatar
I have a 1971 Cutlass "S" It has a 400 in it and I am trying to locate the engine number on it. Does anyone know where I might look for it?
skip79 is offline
Old March 1st, 2010, 08:50 AM
70 cutlass s's Avatar
If your talking about the casting numbers. Then you need to look at the shelf its the flat area behind the water pump in front of the intake. To the right of the oil filler tube.
Also welcome to the site.
70 cutlass s is offline
Old March 1st, 2010, 08:54 AM
Right behind the waterpump in front of the intake, this area may be filled with gunk and crud, wipe it out and post the numbers here. If it is a 400 from '68-69 there will be a vin derivative on a small pad below the number 1 cylinder.
1969w3155 is offline
Alg
January 1st, 2013 05:04 PM
jensenracing77
June 16th, 2011 03:14 PM
radioburningchrome
September 27th, 2009 07:20 AM
ozoneblue
June 4th, 2009 09:13 AM
Quick Reply: Where is the engine number located
