68 442 sway bar
When I added a rear sway from a '69 442 to my rear axle (stock LCAs w/ spacers for reinforcement), it made contact w/ the diff housing. Since then I've swapped to the SSM LCAs and the same sway bar is ~ 1/4" away from the housing. I don't think it does any harm for the sway bar to contact the housing.
Production tolerances on these cars were not exactly "precision" in a lot of cases. You can sometimes simply loosen the four bolts holding the bar to the lower arms, reposition it, and tighten the bolts. It's also possible that the bushings in the lower control arms are worn, causing unwanted motion.
Additionally, make sure the lower control arms are actually "boxed" and someone didnt try to add/cobb a sway bar to unboxed arms. Ive seen this pre-digital age and should have taken a pic for our junkyard dogs thread.
