How to get my 73 cutlass supreme close to 375 hp without replacing my #8 heads
Old July 31st, 2018, 03:14 PM
MrSolidasarock Glover's Avatar
I have a 73 supreme im building with the original olds 350 rocket and i really need some advice on how to get it close to 375hp or to make it a head turner at the least and without replacing my #8 heads or go over my $2500 budget.
MrSolidasarock Glover is offline
Old August 2nd, 2018, 07:14 PM
Gascoop's Avatar
Well there's always nitrous ............. until it blows. Reality is you have to spend money to replace the necessary parts to make horse power. I'm fairly new here also and don't know a thing about 350 Olds engines .......... but an engine is an engine. You need compression, a good set of heads that have been at least pocket ported with larger valves so it can breath. An intake, carburetor, cam and lifters that match the rest of the engine combo + plus a good ignition system. Also, long tube headers.
If your engine doesn't have a lot of miles on it these suggestions may help. If it has a ton of miles and is basically worn out then don't even bother, it's like anything, you have to have a good foundation to build on. Read some of the small block build threads here and you'll get a few ideas.
Gascoop is offline
Old August 2nd, 2018, 09:14 PM
Proud Viet Nam Veteran
redoldsman's Avatar
For $2500 I don't see any way that is going to happen. CopperCutlass has been the master of getting horsepower out of small blocks. He does his own work and uses lots of used parts. If he says it is impossible then you better move on. Good luck.
redoldsman is online now
Old August 2nd, 2018, 10:45 PM
OLDSter Ralph's Avatar
$2500 could buy you some rear end gears, transmission work, and some small trinkets will give you a performance improvement. If you want power, you WILL need a good crank, rods, pistons and bearings to start with. What is your planned use of the car ? Highway or town driving ?
OLDSter Ralph is offline
Old August 3rd, 2018, 06:48 PM
70W-32's Avatar
Rear gears and posi, headers and dual exhaust, trans shift improver kit plus auxillery cooler, base shot of nitrous(no more than 125), performance tune up.
70W-32 is online now
Old August 3rd, 2018, 06:50 PM
70W-32's Avatar
opos
October 12th, 2017 06:38 AM
opos
October 26th, 2016 05:22 PM
ridgefeldboss1
February 26th, 2015 11:58 PM
davoaz
July 17th, 2014 01:18 AM
Cardinal
January 10th, 2009 11:14 AM
Quick Reply: How to get my 73 cutlass supreme close to 375 hp without replacing my #8 heads
