68 vs 72 rear
Old July 30th, 2018, 05:04 PM
Big14's Avatar
68 vs 72 rear
hello everyone I’m the new year this week with a question that maybe considered one of old but anyway here it goes.
i have a 68 cutlass that I recently replaced the 8.2 rear with a 8.5 rear from a 72 cutlass. I now have a rear wheel wobble and believe it to be runout of the flange after ruling out other possibilities.
Question: can the rear axle from the 68 fit in the 72 rear?
2nd Question: my 72 rear has the lugs at the bottom so is this the true 8.5 rear
Big14 is offline
Old July 30th, 2018, 05:37 PM
Don't use the lugs for identification of a '72 rear, instead look at the sides of the center housing for two parallel ribs and at the top of the housing for a boss with a bolt hole for the brake hose mounting block.
If it has two converging ribs or only one rib then it is an 8.2 for sure.
The brake mounting boss on top of the center section is the dead giveaway for the 8.5 rear.
Fun71 is offline
Old July 30th, 2018, 06:10 PM
Big14's Avatar
68 vs 72
ok so I do have two parallel ribs on the sides of the housing as well as the brake line bolting up at the top of the housing.
Does the axle shaft of the 68 fit the n the 72 housing
Big14 is offline
Old July 30th, 2018, 06:16 PM
Big14's Avatar
Also can Mr Brian Trick help with my earlier question of enter changeable axles?
Mr Trick do you have any axles that would work for me?
Big14 is offline
Oldssupreme
Drivetrain/Differentials
July 25th, 2014 08:19 PM
Bob Kelso
November 17th, 2013 03:24 PM
csouth
September 21st, 2012 01:50 PM
jag1886
January 4th, 2011 12:08 PM
47 Convertible
25
December 5th, 2010 09:00 AM
Quick Reply: 68 vs 72 rear
