Trying to decide if I want to buy a 1962 F85
Hi, I'm Chad and a friend of mine told me about this car. I am looking for a low budget father/son project. I don't know much about oldsmobiles and parts availability. As you can, see there is some pretty decent damage in the rear. Are replacement panels available? Would you consider this for restoration, or is it better off left as a parts car? Thanks in advance.
That is some serious damage for a father son project. It is going to be hard to find the parts since nobody reproduces these so used parts will be your only option. Personally I would look for anther car and leave this one to somebody else. It looks like it has been sitting for a long time. Check the classified ads on this site.
Parts are not easy to find for these car. I have 4 of them but two of them are parts car. With this model you need to start with something better to start with. That being said, if you like these cars and want to fix one up, I would recommend buying it as a parts car if the price is right. I would be interested in it if you don't buy it and the price is right.
Given the difficulty of fining parts for these cars, you will be money ahead by starting with a car that is more complete and in better condition. You'll pretty much need to replace that rear quarter panel. I don't know your welding and fabrication skills or available tools, but if you have to pay someone to fix that damage, you'll spend more than the car will be worth. At best, you'll buy another parts car to get a good quarter. Usually in cases like that, the parts car ends up being the one that gets restored because it's in better condition than the original.
Do NOT ask me how I know this...
I think you made a good decision. You can post a wanted ad in the classified section if you decide on a particular car to restore. A bodies are probably the easiest since they are more popular and more parts are available.
Specifically, the '68-'72 A-bodies (especially '70-'72) are the easiest to find parts for since they're the most popular Cutlasses. They're also the most expensive for the same reason. I'd recommend trolling CL for a few months for the right car and not rushing into things. And start with something drivable with minimal rust through.
Not that we've been trying to steal this out from under the OP, but if you do get the car, I'm interested in the rear wheel opening lips, from just in front of the center to the back edge and to an inch or so above the feature line. I suspect the passenger side is crumpled, but even if it's bent a little, I'm still interested.
And I have to quit buying... I picked up a 62 Cutlass with a pile of NOS 62 parts last Saturday. Got a turbo carburetor setup Thursday, A Jetfire 4 speed carburetor Friday, A 62 Cutlass limited slip 3.36 rear end, and now this...
The first step is admitting you have a problem. Now on to step two......
It has 13,s on it. I need to look it over but I believe the quarters are rusted to bad to use as patches. The steering wheel is in GREAT condition! From what it looks, the back seat is great also. I can use that material to make original material front bucket seat covers. The driver seat on my wife's Jetfire has some little tiny cracks and if they get worse I at least have material now. Also has a really nice set of original 62 floor mats! First set of those I ever had. I have family time now so I will look it over better later.
I will let you know. I am not for sure what I want to do with the interior yet. I know I am going to pull it all out so that it does not deteriorate from sitting outside. I would love to hang on to all the interior for a future project but also need to recoup my money from all these cars and parts I have been buying.
the engine runs beautifully. https://youtu.be/rxripxjkwe0
#31
I have another 62 that would be a good father son project but would be major work. It is a 62 Cutlass that is all apart but the majority of the body work is done. Just needs painted and put together. Likely a carburetor rebuild and major tuneup also. Who knows what all you would find good and bad but I believe all the parts are there. I did not want to buy the car because I don't have time to finish it. I bought it because it came with a pile of NOS stuff I wanted. I will loose money on the deal but gain needed parts I wanted.
#32
djboz
May 27th, 2022 06:01 AM
