Newb - 1971 Cutlass Supreme Rocket 350
Old November 22nd, 2018, 06:13 PM
  #41
Just an FYI tidbit for ya
Allan R is offline
Old November 22nd, 2018, 06:18 PM
  #42
Oldsmobile block number
Ah ha - it's CFD not CFO - well done. This is making complete sense now. I was curious about the numbers & I believe I had read 'somewhere' on 'some' site regarding the 'three' numbers on the block and when I was reading it, it appeared to make no sense to me because I was thinking there were 'four' sets of numbers - this is now coming together.
So it's CFD - 409147 - 197 - a set of three numbers.
Spot-on - killer information.
Oldsmobile block
Last edited by Vintage Chief; November 22nd, 2018 at 06:23 PM. Reason: Update image orientation.
Vintage Chief is online now
Old November 22nd, 2018, 06:20 PM
  #43
Ya know, I have that image and for the life of me I could not understand what in the world that number meant. Now it makes complete sense. The number is 409147 - and, not two individual numbers of 409 and 147.
Old November 22nd, 2018, 06:35 PM
  #44
The head will also have the number 7 to the left of the #1 cylinder. This picture shows the 1972 which is basically identical except for the 7 A
The only real difference between the 2 heads is 1971 only had the exhaust seats induction hardened, whereas the 72 had both intake and exhaust seats induction hardened. Not a big deal as both were essentially designed to run on unleaded gasoline./
Allan R is offline
Old November 22nd, 2018, 06:38 PM
  #45
I found essentially three CFD sites:
Saginaw Malleable Iron
Saginaw, MichiganUnited States19192007Iron castings. HQ of Central Foundry Division.Danville Foundry
Danville, IllinoisUnited States19431996
Iron castings. Was part of GM's Central Foundry Division. Leased by Defense Plant Corporation to pour castings for military equipment during World War II.
The above two references are from Wikipedia. The Danville site was apparently for WWII military equipments
The below referenced site I'll need to read up on but is now in EPA Superfund status.
GENERAL MOTORS (CENTRAL FOUNDRY DIVISION) MASSENA, NY
Old November 22nd, 2018, 06:44 PM
  #46
During WW2 all domestic auto production was halted and priority given to production for the war effort, so yes it was dedicated to the military but only for the war years. That required massive retooling and training of workers (mostly women BTW) to build the necessary tools of war, including aircraft, landing assault vehicles, weapons and ammunition, tanks, jeeps/transports etc. Such a massive commitment by the home front to ensure the Axis powers were defeated and our front line troops got the tools they needed to survive and prevail.
Allan R is offline
  #47
OK. I'm going to check out the number 7 in the morning since it's in the back of the engine, it's cold and I'm not in my greasy grubs.
Old November 22nd, 2018, 06:54 PM
  #48
My mother's father worked at the Savanna (Illinois/Iowa) WWII Army Munitions Plant - the largest munitions plant in the country (7500 men) during WWII.
I am familiar with Canada's WWII efforts, as well - as I have friends who reside in Maastricht, Nederlands and I have reviewed and visited the memorial in Margraten which contains both the United States and the Canada battles along the Maas River and Rhine River.
Old November 22nd, 2018, 08:13 PM
  #49
Pretty sure I violated the Rules as pointed out by oldcutlass. I'll post further pictures & requests for information in the best appropriate forums. Thanks for the information everyone - esp. Allan.
Old November 22nd, 2018, 11:14 PM
  #50
People continually ask me who needs AC in a convertible.
Yeah, I used to hear that a lot, too. Must be folks who never lived where it's brutally hot and/or humid most of the year.
It is on the front drivers side as well, which is much easier to see.
While you're looking around that area, snap a pic of the VIN pad on the block. This will show you if it's the original block or not as it has the VIN stamped on it.
The second character of the VIN derivative stamp is the year. A 1974 block would have a "4" in that location. Here's where you will find the VIN derivative stamp on the block:
Here's what the stamp looks like after you clean the crud off of it. Note that this photo is of a 1972 block, as the second character is a "2". Frequent readers may recall that this particular block is NOT a W-30 motor...
Fun71 is offline
Old November 23rd, 2018, 06:22 AM
  #51
Good Morning Kenneth- The VIN derivative # is on my list. I hadn't retrieved it as yet since I believe the alternator bracket is mounted directly over the driver-side stamp location near cylinder #1 position - but I'll have another closer look this morning. I wasn't aware the VIN derivative # was located on passenger side near cylinder #8, as well. Makes sense, same location only reversed.
Old November 23rd, 2018, 07:00 AM
  #52
It isn't. It's only on the drivers side. Just another FYI, the VIN derivative is also stamped on the TH350 housing. (drivers side)
Allan R is offline
Old November 23rd, 2018, 07:05 AM
  #53
Ah right. I kind of misread Kenneth's post - my bad. Now I'll look for the VIN derivative on the TH350 housing, as well. Thanks Allan. Coffee, must have coffee.
Old November 23rd, 2018, 07:47 AM
  #54
I was referring to the head number. You had mentioned looking at the back of the engine for that. Sorry for the confusion.
Fun71 is offline
Old November 23rd, 2018, 09:28 AM
  #55
Kenneth- No worries, my misinterpretation I believe.
Old November 23rd, 2018, 09:36 AM
  #56
I was able to validate the VIN derivatives from both the engine block & the transmission & I believe they were both installed during original production of the vehicle.
VIN Derivative Engine Block
VIN Derivative TH350
Old November 23rd, 2018, 09:38 AM
  #57
Well, perhaps I should clarify. At this point I guess I cannot really say if they were the matching pair installed at the factory during production without further validation (I guess). It would appear (at least) they are a matching pair installed in 'this' vehicle.
Old November 23rd, 2018, 09:52 AM
  #58
You haven't posted a pic of the VIN tag at the base of the windshield on the drivers side. If that number matches the numbers on the block and trans, then it's all factory original.
edit:
Sorry, I missed this earlier. So it is the original engine and trans.
My VIN: 342671M229909 demonstrates the Lansing, MI assembly plant.
Fun71 is offline
Old November 23rd, 2018, 10:11 AM
  #59
edit:
Oh sure - be that way.
The driver's side door panel image (above) matches the VIN tag below the windshield, as well. Yet, what I am doing is establishing photographic documentation to establish authenticity of the vehicle. I just wrote down the VIN # from the windshield VIN tag; yet, it's good to have the photographic evidence - which I'll do, as well.
Old November 23rd, 2018, 10:25 AM
  #60
Old November 23rd, 2018, 12:01 PM
  #61
Ding ding ding...we have a winner. You now have confirmation that the engine and transmission are what the car was born with.
Allan R is offline
Old November 23rd, 2018, 12:11 PM
  #62
I am very pleased to have been able to confirm this. I don't have a 'build sheet' in my hand, I looked in the trunk, rear seat back location, under the rear seat carpeting and thus far no build sheet. I have not looked under the front seat carpet - yet. I know the carpet is not original & the rear seat upholstery is not original. I have new rear seat Sienna upholstery scheduled to arrive 12/7 from Legendary Auto Interiors, LTD.
Old November 23rd, 2018, 12:20 PM
  #63
Allan- Thank you for your assistance in helping me validate documentation - greatly appreciated. This is what I have compiled - comments welcome.
File Type: docx
Old November 23rd, 2018, 12:27 PM
  #64
Would you like a list of options for your car??
Have a look at this link and you'll be able to add in the RPO's (Regular Production Options) that belong on your car. Some things are standard (such as the L34 engine and A51/A65 seats). Compare what you have to this linked page and you'll be even more complete.
Old Car Manual Project - 1971 Oldsmobile
If you run into any problems with interpretation you can PM me or post on the forum.
Allan R is offline
Old November 23rd, 2018, 12:51 PM
  #65
I do have a copy of that image - it was not obtained from the same source, but is identical. Thanks.
I will (eventually) compile a 'pseudo' build sheet of what is 'currently' in the vehicle listing variances from OEM as I move along i.e. the original vehicle would have had an RC Quadrajet 7041250installed (which would have been standard for the 350 engine of this model year); yet, the current Quadrajet is an 7041251 (which would have been standard for the 455 engine of this model year). These types of things are no biggies - yet, documenting variances demonstrates commitment to validate departures from originals - sometimes good, sometimes not so good.
I managed to spend lots of time tearing down & rebuilding vehicle bodies & engines in my youth (TR3A's, 442's, trucks, etc). I am familiar with changing out heads, carbs, exhausts, and the like. Once I gather some additional time this winter (after upgrading the upholstering and noodling about other 'items' I deem appropriate) I'll rebuild this current 7041250because I have familiarity with RC Quadrajets - simple, easy to work on, and really not much to them, IMO - fine-tuning them isn't so bad and IMO they're great carbs. I've (meticulously) cleaned nearly as much of the entire engine and undercarriage as possible, thus far - re-torquing many bolts to spec. The engine is super solid, the transmission is solid and will snap your head back when you kick it down. There are some minor vagaries with the vacuum and carburetor I will be addressing. There is a very minor leak I have not completely isolated which emanates (I believe) from the intake manifold gasket near cylinder # 1. The TH350 has a new torque converter - that's a plus. It's always a matter of focusing specifically on the issue you want to address. With regards to the engine, my next step will involve performing a compression check on each of the cylinders to determine to what degree (if any) there may be a delta in compression among the cylinders. This will enable me to make a more informed decision regarding how 'deep' I need/want to go with addressing the leak issue - hoist the engine, rebuild the top-end; rebuild the top-end 'in-place', do nothing, etc. All in methodically good time.
Old November 23rd, 2018, 02:40 PM
  #66
Since it is a Lansing built car, there likely is not a build sheet to be found as from what has been posted over the years, that plant was meticulous about throwing them away at the end of the assembly line instead of tucking them into some spot on the vehicle. Anyway, another place they have been found is on top of the gas tank.
I will (eventually) compile a 'pseudo' build sheet of what is 'currently' in the vehicle listing variances from OEM as I move along.
I did similar with an Excel spreadsheet showing the standard and optional equipment on my car.
Fun71 is offline
Old November 23rd, 2018, 03:09 PM
  #67
I can understand & appreciate each of your statements regarding build sheets. Above the gas tank? I have an image of an assembly line worker holding the build sheet as the frame w/ attached/mounted gas tank moves down the line. The worker lays the build sheet on top of the fuel tank and the body is lowered onto the frame. Build sheet may not have been needed any longer.
I'll probably create an Excel spreadsheet as I move along noting standard/optional equipment & current equipment.
Thanks for your input, Kenneth.
Old November 29th, 2018, 04:16 PM
  #68
...71 cars had hardened exhaust valves, but not intake.
I believe you're referring to the valve seats, not the valves themselves - maybe both were hardened, but I don't think so? In any case, beginning in 1971 all GM divisions (except Pontiac & Buick) began induction-hardening the exhaust-valve seats of their cylinder heads. I recall this period well - the introduction of low-level/non-leaded fuel while my friends & I are thinking - hmmmmm....what about our exhaust valve seats coated in lead - what's going to happen to them w/ unleaded?
Old November 29th, 2018, 05:21 PM
  #69
Yes, you're correct. I was referring to the valve seats. It was 1972 when Olds had induction hardened valve seats on both intake and exhaust. The introduction of no lead was anticipated and even today you would have no trouble whatsoever using regular 87 octane in your car. I know what the owners manual says about octane requirements, but that was a different rating system. The 87 oct today is the equivalent or better than the required fuel back then. (disclaimer - unless you go to a high mix of ethanol which is total crap for any engine except the E85 flex fuel cars)
Allan R is offline
Old November 29th, 2018, 05:44 PM
  #70
This site has a plethora of knowledge w/ a diverse group of posters and some really exceptional moderators.
On another note, I'm replacing the intake manifold gaskets & valve cover gaskets.
Old December 13th, 2018, 02:27 PM
  #71
Intake oil valley, push rods, rocker arms, spring valve seals, keys, & pivots thoroughly cleaned & flushed w/ one gallon diesel fuel and one gallon conventional 10-30W detergent oil. New intake [metal turkey tray] manifold gasket & valve cover gaskets installed. Trending in a positive direction. Moving on to R&R oil pump.
Before
Original Valve Cover - Underside - Cleaned
Original Valve Covers - Refurbished
Refurbished Intake & Valve Covers
Old December 13th, 2018, 03:39 PM
  #72
You didn't need to replace any valve seals? Can't remember if you did a compression test before but something tells me you have done both a dry and wet test.
Allan R is offline
Old December 13th, 2018, 03:53 PM
  #73
Hi Allan- Valve seals not necessary. You're correct, from my thread 350 Stock Small Oil Leak.
Table re-posted below:
File Type: docx
Old December 13th, 2018, 04:02 PM
  #74
I know someone at some point in time did some type of valve, seal, push-rod work as at least one rocker arm pivot was a different type metal than others; and, it's possible several others were of a slight difference in appearance, as well. At least one without question was not original. When this work was done - who knows. Based on my examination of the aforementioned thoroughly cleaned items coupled w/ my dry/wet compression test I saw no reason to dig any deeper.
Old January 3rd, 2019, 10:03 AM
  #75
I agree. That sticky was created way back before all the changes to the forum.
Allan R is offline
Old January 3rd, 2019, 02:44 PM
  #76
Admins don't control the file size you need. That is Internet Brands jurisdiction unless I'm mistaken. Admins can certainly advocate for you but I think the forum would benefit more from a new Posting Pics thread than mpeg. Some users may also be limited with their viewing media.
Allan R is offline
Miles71
January 31st, 2020 06:53 PM
jmcdona
July 29th, 2018 08:56 AM
eazy
June 26th, 2013 06:33 AM
Mark47
March 5th, 2013 08:13 PM
Cobrar980
April 13th, 2010 06:40 AM
Quick Reply: Newb - 1971 Cutlass Supreme Rocket 350
